Remote fuel pump plumbing question - Novi carbs
    Sep 2007
    In the water
    I have a remote fuel pump. See attached picture. It has 2 fuel supply nipples on it. Im running 44 Novis with the fuel rail. Only one fuel in and then the fuel return to the tank. Can this pump work? I feel I need to buy the fuel pump with only one fuel supply?fuel pump.jpg
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Resident Guru Dano 7's Avatar
    Nov 2003
    PA
    Re: Remote fuel pump plumbing question - Novi carbs
    Quote Originally Posted by River Rat View Post
    Yes. Will work fine. I run this pump with a GroupK air separator on my 800 & 1100. I have two inlets on separator that go to one feed fitting. You could "Y" the 2 supply fittings together to have one feed fitting going to rail. You follow me ?
    Dano 7
    96/99 ZXI 1100 - Parting out. Have engine & ebox and misc stuff. No hull. PM me for other needed items.
    02 SXI PRO
    04 SXR 800
    19 SXR 1500
    17 YZ 250X
    Sep 2007
    In the water
    Dano, Thx you. I read ya loud and clear. I was thinking this then started to think that there might be to much pressure and would have circuits leaking making the tune of the carbs a pita. I appreciate it your help
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Dec 2011
    Niceville, FL
    That's adjusted by the size of jet your running on the return fitting.
    SE MI
    I've been running one of these into a "T" that feeds a Buckshot 50mm billet carb - no problems.
    Sep 2007
    In the water
    Quote Originally Posted by Matt Braley View Post
    720 hx 44 novis factory pipe 34cc domes 3 degree advance: What size jet would you use to keep the pressure in the fuel rail?
    SeaDoo Hx
    Kawi 750 sx
    Kawi 550
    Dec 2011
    Niceville, FL
    65 is a good starting point. I've gone up to 80 though.
