    Top Dog Benflynn's Avatar
    Aug 2015
    Birmingham
    95 tigershark 900/1000 miss is over 6k
    We cleaned carbs and took out ts 900 with what seems to be a 1000 in it, to the river, runs strong, spins at the slightest hint of a u turn, but above 6k rpm it would cut out. It acts excactly like a rectifier on a seadoo going out, and the rectifier was kinda hot to the touch when I checked it. This thing did come with 7 giant boxes of ts parts so I have a regulator and 5 full eboxes to try, just wondering if it is a common problem before I start throwing free parts at it.
    Oct 2013
    Ohio
    Re: 95 tigershark 900/1000 miss is over 6k
    Explain more what you mean by cut out. Does it totally stop running until you get below 6k? OR, does it start to run rough when you get to 6k, like it is just not firing correctly but it continues to run.
    Aug 2015
    Birmingham
    It's like a solid cut, electrical for sure, when I first heard it I thought the wear ring was bad and it was running up on the limiter
    Clip plug wires back, ohm out boots, try new plugs. Do this first.
    Aug 2015
    Birmingham
    10-4
