Carb jetting for elevation
Results 1 to 10 of 20
    Apr 2008
    SoCal
    Are there any known formulas for jetting according to elevation? I have my jettings proper for sea level but im planning a trip that is at 6000 ft. elevation. This is for a GSXL 951cc engine. Thanks
    Jun 2011
    Re: Carb jetting for elevation
    I don't know if any formulas.
    But I think this might help:
    What would Chuck Norris do?
    You would be better of lowering your impeller pitch so it reduces load on the engine so it can operate at the correct rev range at WOT within the correct heat range.
    Its the easiest thing to do than trying to re jet,I would grab an impeller that's at least 2 degrees less than what you have now
    Cypress, TX
    At +6000 ft elevation, aprox. 2000 meter is the reference chart point which indicates only a 2.5 reduction in Main Jet Size.
    You can easily compensate by turning the High Speed Adjuster Screws IN to lean out the mixture. No need to rejet at that elevation.
    Use a good Tachometer to fine tune the carbs.
    Cypress, TX
    However, at +6000ft elevation there is a corresponding drop in atmospheric pressure of 3 psi (from 14.7 psi at sea level to 11.7 psi at 6000 ft) which will affect pop-off pressure requirements.
    "Pilots who fly at high altitudes (1,200m MSL/4,000' MSL and above) may want to adjust the pop-off pressure by adding shims to the existing spring or replacing the spring with one of greater compression strength"
    Apparently, a stronger spring is needed to make-up for the extra 3 psi needed of pop-off pressure.
    Need someone who rides regular at +6000 ft to let us in on the pop-off adjustment...
    Cypress, TX
    I think the 947 seadoo carbs high speed adjustments are set at zero turns out? If so, then downsize main jets while you're swapping springs...
    Apr 2008
    SoCal
    Thank you for the mikuni chart Cliff. good enough formula for me.
    SurfNturf, impeller is a great idea, maybe ill do both. Have plenty of time to prepare
    JC, the chart is in -Ft. and not in -Meter. Its a bit blurry so i googled for more images and found a higher resolution one. With that said 6000 ft elevation calls for an 8 points change, but what i dont like is it figures only for the HS circuit... i do like the idea of going with a heavier spring to compensate for the atmospheric pressure. I may try that along with 5 points less on the HS jet
    Yes we need someone from like UT or CO to chime in
    Jun 2011
    Spades,
    Is this a stock 951cc engine?
    Cypress, TX
    Ooops...looks like I need new reading glasses...
    Apr 2008
    SoCal
    Quote Originally Posted by Cliff View Post
    Just has flame arresters and disabled accelerator pump, and rejetted accordingly
