    Dec 2005
    Page, Az
    Kawasaki ultra lx run issue
    I have an 09 Kawasaki ultra lx non s/c that starts and idles fine, runs up to speed, if you let off the throttle fast it stalls but will fire right back up again. Any body else had this happen? I already replaced the throttle body with another known working one from an 07 ultra that I parted out. I also replaced the sensor that goes right below the throttle body. took it to test run same problem. any help would be appreciated.
    Feb 2015
    Southcoast ma
    Re: Kawasaki ultra lx run issue
    Sounds like the ics motor,very common problem
    Dec 2005
    Page, Az
    where is the ics motor located and what does it look like?
    Feb 2015
    Southcoast ma
    Small electronic motor on throttle body,has 3 small screws holding it on,usually seal goes bad,have to change isc motor. Jet ski will accelerate normal,but will stall when you let off.
