polaris msx 140 center cylinder failure pics need help diagnosing
Results 1 to 8 of 8
    Sep 2010
    fresno ca.
    trying to figure out what caused this center piston on my 2003 msx 140 di to do this... oil failure, lean condition??? and if lean what then fiect injectors or whatever they're called?? can i run some sort of premix leaving a crank case oil line hooked up to lube the bottom end and remove oil lines from throttle bodys?IMG_2263.jpgIMG_2264.jpgIMG_2265.jpgIMG_2266.jpgIMG_2267.jpgIMG_2268.jpgIMG_2269.jpgIMG_2270.jpgIMG_2271.jpgIMG_2272.jpgIMG_2273.jpgIMG_2274.jpgIMG_2275.jpguIMG_2276.jpgIMG_2277.jpgIMG_2278.jpg
    Resident Guru 785 lugs's Avatar
    Feb 2005
    chicago il.
    Re: polaris msx 140 center cylinder failure pics need help diagnosing
    most likely fuel pressure
    Sep 2010
    fresno ca.
    You think replace fuel pump?
    Feb 2005
    chicago il.
    it's usually the fuel pump regulator that falls off and causes low fuel pressure and then the ski starts to run lean and that starts the melt down
    Nov 2004
    Homer, NY
    Debris damage on the piston. Usually from a crank bearing disintegrating.
    Bummer.
    '03 Octane, Watcon 2318 CDI
    Apr 2017
    Quesnel BC
    that looks like my buddies pistons after he ran his ski without oil for 10 min,,,,,boom
    Jun 2015
    Mass.
    Whar number cyl ? I just picked up 2 one is looking like yours Iam new to these rides so iam resreching everything ill let you know what i find
    I think that all started with a mechanical failure of the lower ring. Once that ring started breaking into pieces, the schrapnel did everything else.
