    Dec 2011
    Niceville, FL
    Bad Batch of Seadoo Fuel Valves
    I was having great luck with these so before last season I loaded up on them. They were out of stock for a bit and then after these came in I started to notice they were DOA. These all leak air straight in and out of them.
    I talked with someone else who had the issue and they said you guys knew about it and covered him on it. Would it be possible for me to trade these back in for good ones? Thanks in advance.
    Re: Bad Batch of Seadoo Fuel Valves
    Contact our customer service department, and we will see what we can do for you. 877-330-0231
    SBT Tech Support is here to help with your problems.
    We try to answer each question quickly and accurately.
    Please do not use Private Messaging for Tech Support, use the forums.
    Dec 2011
    Niceville, FL
    Thank you calling now.......
