    Frequent Poster chris_65_mustang's Avatar
    Dec 2012
    windsor, ontario
    2000 GTX running lean
    I have a 2000 GTX we have just rebuilt the motor. It runs great on the water but its running lean. I have rebuilt the motor with all new gaskets and seals, rebuilt the carbs, opened the high speed and low speed up 1 turn above the recommended settings and its still running on the lean side. There is lots of fuel being pumped. Anyone have any suggestions as to why this is happening?
    May 2009
    South Carolina
    Re: 2000 GTX running lean
    How do you know you are running lean? Did you do a plug chop or are you just looking at the plugs after normal running? What about your oil system?
    Think Big!!
    Dec 2012
    windsor, ontario
    Looked at the plugs after about a 2 minute ride. New plugs and after running at about 3/4 throttle pulled the plugs to check them. Oil injection system seems to be working and pumping fine the oil pump cable is adjusted properly.
