951 Rectifier regulator bypass - Page 2
Results 11 to 20 of 31
    Oct 2013
    funky town
    Re: 951 Rectifier regulator bypass
    Um, not even close to 3 phase as far as AC. How many wires you have on a standard 110 volt outlet? 3, right? Hot, neutral, and ground. True 3 phase has 4 wires. The 3rd leg can actually be generated with a phase converter, which is either rotary or static. The difference is how you start the motor which generates the 3rd leg.
    I have, do, and can build them all the time.
    Maybe there is a translation error, here.
    I don't have time to get into this right now. I'll look it up and see, but I think you guys are mistaken. Unless 3 phase means something different for a stator....
    I'll be black!
    I'm only here to make you mad
    Oct 2013
    funky town
    Hey, guys. Please don't try to wire your shops. You WILL fuk yourselves up.
    Oct 2013
    funky town
    Aw, fuk. I forgot it's dc. Three different pick ups can "technically" be called 3 phase. Right?
    3 different generation points can be called 3 phase in a dc setup. I guess it's the same, but it's not. 3 phase ac will kill you. 3 phase dc will make you shake your head. 4 wires for 3 phase ac, 3 wires for "3 phase" dc. Huh. I'd rather run with the voltage, and number of pick ups. Calling it 3 phase is bullsh!t.
    Oct 2013
    funky town
    Carry on.
    Nov 2002
    CA
    I know you said carry on, but..
    The 120v AC has 3 wires because of having a ground, technically 2 legs are carrying the power. In 3-phase you have 3 legs carrying the power, and a 4th wire for ground.
    No actually it's AC, three hot wires, three separate interwound coils which translates into three legs, then you have a ground wire to boot, this is on all 787'S, 951's and 4 TECS. In other words yes I actually know whatdafuc I am, talking about.
    Oct 2013
    funky town
    I am eating cheerios.
    4 wires for 3 phase. I know this. I started in earlier because it was stated incorrectly.
    Also,drinking basil Hayden's Kentucky bourbon. Don't give afuk anymore. I' m out. My electrical game is on point. Bottoms up!
    Oct 2013
    funky town
    Oh, man. Cheerios and bourbon. You should try it. I'd bet that honey nut cheerios and bourbon would be KILLER!!!!
    WFO, I know it's ac, I misspoke on that one. That's why it'll get you! Not exactly ready to call it true 3 phase, though. Aw fuk it, who cares. As long as it runs, call it an underage girl smoking crack! That's 3 phase, right? Daddy issues, wants to be liked so she puts out, and drug abuse. See, 3 phases.
    Frequent Poster Keno's Avatar
    Sep 2010
    Kansas
    I've had the older version of this kit on my 96xp for the last several years. Works well. http://osdparts.com/index.php?main_p...ifier+external
    96 xp - not stock
    RCW Brawler
    Braap!!
    May 2009
    South Carolina
    Drinking and blogging should be illegal!!
    3 Phase does not need 4 wires - each phase is 120 degrees out and the current returns on the other phases depending on where the voltage of each particular phase is. Ground is for safety and also creating other single phase supplies from a 3 phase source. The stator on a Seadoo is a 3 phase Voltage generator. The rectifier regulator rectifies AC to DC and regulates it between 13.5 and 14.5 Volts.
    Think Big!!
