Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Jul 2016
    Charlottesville
    Carb Needle Seat Stuck - Help
    I am rebuilding dual Mikuni carbs in a 99 GSX Limited today and the seat on one of the carbs will not come out. Does anyone know any tricks? Yes the retainer screw and holder are out. Just stuck.
    Posting on a couple boards in case you see somewhere else.
    I dream skis JC-SuperJet's Avatar
    Cypress, TX
    Re: Carb Needle Seat Stuck - Help
    Jul 2016
    Charlottesville
    using pb blaster but nothing.
    Jun 2011
    Soak with PB Blaster & lightly tap with a ball peen hammer to shock the corrosion loose...
    If at first you don't succeed...
    Then you're NOT Chuck Norris!
    Jul 2016
    Charlottesville
    Thanks Cliff. been doing that
    Jul 2016
    Charlottesville
    Soaking in PB overnight. Trying not to mangle top of seat but its so soft.
    Put grooves in it for screwdriver but on my got to move side to side a little.
    Remove the fuel pump side of the carb, drive out the old needle and seat with a pin punch, replace with new needle and seat.
    Get your Fat Dudes T-shirts right here PM me for details !
    Jul 2016
    Charlottesville
    My filter doesn't really line up
    It should line up enough, I have done them this way before or I would not recommend this method to you, you could also use a dent puller (small slidehammer with a screw) screw the screw into the needle and seat and slidehammer it out.
    One more idea for you a small easeout chucked into a reversing drill should pull it out
