Results 1 to 10 of 16
Thread: 951 gsxl 97
    PWCToday Guru Rconce01's Avatar
    Mar 2007
    miami
    951 gsxl 97
    Low power won't rev past 2,000 rpm on the water.
    About a month ago a had a piece of metal of the Bendix wedge itself into the magneto and lock the motor and short the magneto. I put a new magneto in there and the ski revs outside the water but dies inside the water. Both cylinders have 125 psi and both spark plugs spark. Both cylinders are getting good fuel but the rear one refuses to fire. The magneto issue blew my 15 amp fuse on the MPEM .
    Can something electronically be damaged in the MPEM that would cause one cylinder to not fire?
    By the way the ski runs the same with or without the rear spark plug cable connected and the reeds are good. Also even if I connect and install the front spark plug and cable in the rear it still wont fire.
    What can be damaged when a magneto shorts and blows the fuse?
    Mar 2007
    miami
    Re: 951 gsxl 97
    This is a before and after photo of the mess.
    By the way is there any specific order to the placement of the 3 yellow wires into the plug? I didn't mark them in any specific order and now I see this video and I'm thinking I may have needed to analyse the placement of each one relative to the other two.
    https://youtu.be/NnOO8YYrL_M
    Re: 951 gsxl 97
    Blown head gasket ?
    Riverside, CA
    6
    Re: 951 gsxl 97
    There should be two 15 amp fuses that are part of the charging system.
    The rectifier is a probable cause for the 15 amp fuse to blow, and the charging
    system may be the cause of the running problem.
    You might need a multi meter with an amperage clamp to test this, and
    you will need the manual.
    Bill M.
    Mar 2007
    miami
    Re: 951 gsxl 97
    Bill M.
    OK Bill thanks I have clamp on ampmeter it can measure DC and AC current. In DC it shows 8 amp current while it's running and voltage climbs to 13.5v .
    I read something about getting some AC voltage to the battery when the rectifier is partially damaged.
    If I cut the 3 magneto wires the running problem should disappear if it's a rectifier issue?
    Feb 2002
    Vancouver, BC Canada
    Re: 951 gsxl 97
    The rectifier is a probable cause for the 15 amp fuse to blow...
    Bill M.
    The blown 15 amp fuse was due to the shorted stator.
    Quote Originally Posted by Rconce01 View Post
    Did you cut back the plug wires? Replace the spark plugs and check the resistance of the coil and the plug caps.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Feb 2002
    Re: 951 gsxl 97
    You just have to disconnect the red wire.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Mar 2007
    miami
    Re: 951 gsxl 97
    Chester
    Cool thanks , I did the 1/4" wire clip and the new plugs buy I didn't do resistance testing on the coil or the caps. I'm not sure which red wire my rectifier is built in to the mpem. I do see the 3 yellow that come out of the magneto housing.
    The fuse is good.
    Riverside, CA
    6
    Re: 951 gsxl 97
    After the good test of the charging system, I came to the same conclusion.
    8 amps a bit high. Spec is 5 amp at 5500rpm.
    Other than that, I didn't have any good input. I can't remember seeing a 951
    run at only 2000rpm.
    The only advice I can give is to check the basic easy stuff similar to Chester's
    Advice.
    Bill M.
    Check the fuel filler cap's gasket.
    Another simple test: Dump the fuel filter bowl onto a table and check for water.
    Water doesn't like to flow through carb jets. Then replace the filter o-ring.
    Mar 2007
    miami
    Re: 951 gsxl 97
    Advice.
    Bill M.
    The charging system seems fine 13.5v dc and .3vAC running. I pulled the 3 magneto wires and I get 45 to 50 ohms on all phases . The magneto makes 35v at idle and if I Rev it got up to 80v AC . Same crap with all magneto wires pulled looses all power on the water. Can it be a broken reed valve? It's making a weird clacking sound in the motor.
