Results 1 to 6 of 6
    Jul 2016
    Charlottesville
    951 GSX 99 Which tube to clamp for tow?
    Having trouble seeing which tube to clamp on the 1999 GSX 951 LImited when your are towing. There are 2 tubes that come in through the back. one goes under engine and goes up into the big exhaust tube at front of engine. The other goes down side to near where rave valve lines and sensor are.
    If anyone has a pic that would be great.
    Is it just the tube that connects to flush fitting on outside?
    Jul 2016
    Charlottesville
    Re: 951 GSX 99 Which tube to clamp for tow?
    bump to top. Thanks
    Riverside, CA
    6
    Make sure your clamp completely pinches off the cooling line, to prevent
    water from filling the exhaust pipe.
    Bill M.
    Jul 2016
    Charlottesville
    Bill M.
    So I assume you mean the clamp where the red X is?
    This is the larger diameter hose that runs up front and goes into the bottom of the tuning pipe (exhasut) correct?
    Sep 2015
    Northern Michigan
    Yes
    Jul 2016
    Charlottesville
    Quote Originally Posted by Hydro-Mike View Post
    Yes
    Mike to the rescue again. Thanks buddy.
