Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Mar 2008
    so cal
    951 carbed, no spark in rear cylinder
    It's a 98 model, at the lake it'll start up and idle, but won't rev up and will die. I check the plugs and the rear plug tip is clean no oil stains, the front plug looks normal with oil stain on the tip. So I'm assuming no spark to the rear cylinder, any idea what's causing this or what needs to be replaced?
    It has a new stator, new bendix gear, new battery and it's getting faint sound of the two beeps with lanyard attached.
    carbs have been cleaned, fuel selector valve bypassed, and fuel lines changed.
    Re: 951 carbed, no spark in rear cylinder
    Cant happen as both plugs fire at the same time.
    Dont assume,check for spark. Then check compression,my guess is something was not done right in the carbs or could be a broken reed.
    Sep 2015
    Northern Michigan
    Could be a poor wire connection, in the spark plug wire.
    Resident Guru Bionic racing's Avatar
    Idaho/California
    With out compression fuel won't burn and change color , at this point pull plugs and put finger over plug hole and crank , that will let you know what's up
    Riverside, CA
    6
    Don't assume,check for spark. Then check compression,my guess is something was not done right in the carbs or could be a broken reed.
    Good Advice
    Quote Originally Posted by pwc enthusiast View Post
    Obvious it isn't running on the rear cylinder.
    Stop trying to run the engine, you could make the problem worse.
    My advice is check the compression.
    If there is any raw gas inside the cylinder, it can be dangerous to
    check the spark.To prevent an accident:
    When you check the spark, do it with the old spark plugs in their
    holes. Ground a set of new test spark plugs against the old spark
    plugs in the head. Then test the spark.
    It is easier to see the spark on non-resistor spark plugs.
    Bill M.
    Mar 2008
    so cal
    I tried checking compression and it shot up to 190psi because it was flooding with fuel in the rear cylinder.
    I removed compression guage and cranked it over to get the fuel out and it just keeps shooting a load of fuel out evertime the engine cycles. So now i can't check compression, and the fuel is washing away the oil stain on plug tip, and since they spark at the same time, I'm guessing I have spark and the issue is in the carbs not electrical.
    Idaho/California
    Where are you located in california , if close to me bring it here and have diagnosed in 5 minutes , no guesswork
    Mar 2008
    so cal
    I gave you all the symptoms, what's the diagnosis?
    also I shouldn't say im guessing I have spark, I do have spark because I was able to idle the ski to the island where we post up.
    Thanks in advance.
    Riverside, CA
    6
    That is how fires get started, that is why I made this recommendation.
    You will be fortunate if it turns out to be a broken reed as Grumpy Old Guy
    suggested, or a problem with the needle and seat leaking.
    If the lever height is too high, the seats will leak as soon as the float diaphragm
    is installed. So if you tested pop-off like normal, the seats will leak after final assembly.
    I would test pop-off immediately after they were pulled off, while the carbs are still
    assembled. Do you need help with making your own pop-off tester.
    Because it was an ~early 951, I was leaning towards a water damaged
    piston that has seized, and lost compression.
    But I sincerely hope it turns out to be an easy fix.
    Bill M.
    You have a carb issue.
