Results 1 to 10 of 15
    Jul 2016
    Charlottesville
    99 GSX Limited sits low in water
    I noticed the first time riding this ski that it sits very low in the water when you get on it and when a second person gets on it, it seems very unstable. Almost like it is too much weight. Combined weight for the 2 people was 310 lbs. I know the limit is 350 or close to that, but it seemed like the water came up higher than normal in the foot wells and back end was down in water a lot. Moreso than any other ski I have ridden. Can anyone comment on this? is this normal for this model? Seems like it was maybe just made for 1 person? Thanks
    Re: 99 GSX Limited sits low in water
    With 310 pounds it sounds fine to me. That an older, less buoyant, narrow machine.
    Jul 2016
    Charlottesville
    Not my machine, but here is what it looks like.
    Jul 2016
    Charlottesville
    Can it be made more buoyant? Ever seen that done? Adding foam?
    May 2009
    South Carolina
    Should have bought a GTX for 2 riders. Adding foam would not make it more buoyant. You would have to change the hull dimensions to do that - water displacement is king.
    Think Big!!
    Jul 2016
    Charlottesville
    got it. Thanks
    Jun 2004
    DFW- Texas
    Here is how a GSX should sit in the water as well as a 96 XP with full tanks of gas.
    16 RXP-X 300
    JS 550 with 650 Conversion
    04 RXP - w/mods - SOLD
    99 GSX Limited #1- SOLD
    99 GSX Limited #2- SOLD
    96 XP- SOLD
    95 XP- SOLD
    94 750sx- w/mods- SOLD
    94 SN Superjet- w/mods- SOLD
    04 Speedster 200 -SOLD
    Sep 2014
    GA
    if you think a GSX is unstable...Don't EVEN look at an X2, HX, WB1, etc. HAHAHA
    Jun 2011
    Quote Originally Posted by pharmacist25 View Post
    Is your ski missing some of the floatation foam?
    I have owned my '96 GSX 800 since Aug. 1996 and have ridden with an adult on the back as a passenger without issues over the years and believe that the GSX 951 has a similar platform.
    I feel that the GSX platform is a true 2 seater ski and the X4 platform is suited for 1 adult and a small child. The HX, X2, 3D & similar models are true single rider platforms.
    But maybe some of the foam is missing causing it to sit low in the water or maybe there's water sitting in the hull already?
    If at first you don't succeed...
    Then you're NOT Chuck Norris!
    Feb 2002
    Vancouver, BC Canada
    Quote Originally Posted by Cliff View Post
    If you take all the foam out, it will sit slightly higher in the water, not lower due to less weight. The foam only comes into play when the hull is full of water, it prevents the ski from sinking to the bottom of the lake. Read hafweigthr's post. The only ways to make it float higher is to remove weight or increase the size of the hull.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
