Results 11 to 15 of 15
    Feb 2002
    Vancouver, BC Canada
    Re: 99 GSX Limited sits low in water
    Quote Originally Posted by pharmacist25 View Post
    I noticed the first time riding this ski that it sits very low in the water when you get on it and when a second person gets on it, it seems very unstable. Almost like it is too much weight. Combined weight for the 2 people was 310 lbs. I know the limit is 350 or close to that, but it seemed like the water came up higher than normal in the foot wells and back end was down in water a lot. Moreso than any other ski I have ridden. Can anyone comment on this? is this normal for this model? Seems like it was maybe just made for 1 person? Thanks
    Is there water in the hull?
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    PWCToday Newbie koffandkurtskiis's Avatar
    Apr 2016
    Usa
    Quote Originally Posted by vdubspeed View Post
    if you think a GSX is unstable...Don't EVEN look at an X2, HX, WB1, etc. HAHAHA
    Funny that you should say that
    Jan 2006
    Smoky Mountains TN
    The only ways to make it float higher is to remove weight or increase the size of the hull.
    Chester
    Before I ride I like to stop by the party balloon store and have the hull filled with Helium - Makes the ride ultra smooth, glides over waves and wakes - Only drawback is I cannot open the storage hatches or remove the seat all day.
    Aug 2012
    whitby ont canada
    This may be way off base but I got a hull ( 96 XP ) for a project and when taking from the truck to the shop cart it seemed to be heavier than normal, empty hull, after looking around at it I found a chip in the hull down to the fibreglass mat, I drilled 2 small holes at the back of the boat and this thing dripped water for 2 days, the foam between glass layers was full of water, I would look over your hull real close or possibly weigh the boat and compare to new weight,
    Jul 2016
    Charlottesville
    Quote Originally Posted by 1957Dave View Post
    Just saw this and funny you should say that but I noticed it was extremely heavy when we slid it off the trailer. Will check
