Results 1 to 10 of 13
Thread: Manual trim...?
    I dream skis DamageInc's Avatar
    Apr 2014
    Pismo
    Manual trim...?
    I've looked through the countless threads and old pix, but haven't found a true manual trim for an x2. I've based what I came up with off of a few designs from this site, but feel that the nozzle is forced upward by the pump pressure. I put a couple springs on the bottom of the nozzle, but now I need two hands to squeeze it.
    Is is there a production version made by anyone?
    I'll post pix of my set up...
    96 xp stocker w/ the works
    96 xp stocker
    96 xp project
    92 X2 650/750 conv build
    90 JS440/650sx conversion
    04 YfZ450
    05 GSXR 1000
    Oct 2013
    funky town
    Re: Manual trim...?
    I have to manually trim, too. I did find a massage parlor that would do it for me, but they had cold hands, and they charged WAY too much.
    I did learn what a happy ending is, though.
    I'm only here to make you mad
    Oct 2013
    funky town
    Re: Manual trim...?
    I don't think anyone is currently making a production trim setup. I mad a few, but no longer have those skis. X2guy (I think) made some, but no longer. The hardest part is getting a cable and lever (at least for me). the rest was fairly easy, but I have some cool tools to facilitate the job.
    Are you seeking a drop nozzle for racing? Mine were designed for more freestyle/playful riding for up trim.
    Re: Manual trim...?
    I put the twist grip trim from a gpr on my sons xp. Works great.
    Oct 2013
    funky town
    Re: Manual trim...?
    Really? For a drop, or an up/freestyle type?
    Pics or it never happened.
    I just want to see it. A twist grip could get a wee bit itchy at times...
    Aug 2010
    Australia
    Re: Manual trim...?
    somebody did one utilizing a bicycle cable and lever , some stainless springs from the hardware and a few other miscellaneous odds and ends !, i believe it worked well since in the natural realm of physics the nozzle reverts to a strait position when the OEM cable breaks ""i know these things !""
    modded X2 650
    Originally Posted by hyosung
    Re: Manual trim...?
    Thread is here. http://www.pwctoday.com/showthread.php?t=446834
    My son mostly plays around nose up!
    Sin City USA
    Re: Manual trim...?
    I had a drop nozzle setup, it was very straightforward... UMI lever, a custom length cable and a Skat Track drop nozzle. The entire setup is in my '93X2 build thread.
    Oct 2013
    funky town
    Re: Manual trim...?
    Jon, I have a feeling he's looking for a freestyle setup. The cable setup is a little weird for that, hence why no one produces one. The x2guy (maybe?) one had a pivot point mounted to the original trim mount on the hull, and it was sort of just out there, although having never seen one in person, I do not know. I have heard that his setup was good!
    Who likes cheese?
    Apr 2014
    Pismo
    Re: Manual trim...?
    Yes, looking for a freestyle setup I suppose.
    Didn't like the stock version, so I tried following a few leads from members here.
    I inverted the stock handle mechanism under the top deck, flipped the trim nozzle, ran a 48" Silver Jacket cable thru the stock exhaust water exit tube and connected it to a lever on the trim mechanism. Then ran a short cable up through the top deck and around to a Blowsion trim lever. Put a couple springs on the bottom side of the nozzle to keep it down. The pull on the lever was tight, but usable. But when it was under load in the water (in motion) I don't think the springs were taut enough to keep the nozzle down, cuz when I pulled the trim lever, I didn't see a change in the pumps direction...and it already appeared to be pointing more up than down...
    Just trying to find a simple setup to use the trim.
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
