Results 1 to 9 of 9
    Frequent Poster Jsx550's Avatar
    Aug 2012
    Wyomissing, pa
    Thunder Jet, Viper and VHP 7000
    What is the difference?
    was the VHP 7000 the predecessor to the Thunder Jet?
    i am considering buying a 1990 VHP! Therefore I ask...
    Sep 2005
    AZ
    Re: Thunder Jet, Viper and VHP 7000
    You're not going to find a 1990 VHP. They were only available to the public in 1995...not even prototyped until 1993.
    VHP7000 is a boat built by PJS. Hull, Motor, Pump...everything.
    Thunder Jet was a model name made by Laser jet. Available in 1992 and 1993. It had a PJS motor and pump. Laser Jet was out of Huntington Beach, Cali.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust.
    Riverside, CA
    6
    Did you ever see the Laser Jet rescue boat made from 2 laser jet hulls?
    Bill M.
    Mar 2005
    Santa Barbara, Ca.
    Bill ... Is that what the Viper 9000 motors were for?
    Bill M.
    Sep 2005
    AZ
    Bruce - those were for the PJS sit downs.
    "Viper" was a term used on the engines. The stand up was technically called a VHP Viper with a Viper 7000 engine - dual 38mm carbed 550.
    Mar 2005
    Santa Barbara, Ca.
    Quote Originally Posted by MrSki View Post
    Well I have a PJS Seajet and it is not the same as the Viper 9000 motor at all
    The 9000 is like a Supercylinder motor but the reeds are in the cylinders like a 550 PJS cylinder
    I read somewhere the 9000 motor was developed for a rescue boat
    Riverside, CA
    6
    The large cylinder reed engines were designed to be connected to a
    jet pump assembly for small jet boats.
    They were similar to a Yamaha pump assembly with a bed pan connected
    to the pump gullet, and they had a reverse gate.
    Some of them had pumps that snapped to the bulkhead mount and pump
    gullet to allow easy clean out of weeds and debris.
    Bill M.
    Mar 2005
    Santa Barbara, Ca.
    Bill. Any pics of the rescue boat dual hull?
    Riverside, CA
    6
    Not that I am aware of. It was a long time ago when I saw it.
    I remember the basic outline but not the details.
    I am fairly certain mtrhead worked there before he worked at Kawasaki.
    Bill M.
