Results 31 to 38 of 38
  1. #31
    Re: Yamasaki vibration ??
    We have a customer that likes to buy weird things.....Kawi SC with a Yami 701 that does the same thing,bad vib just off idle. His first ride shook all the exhaust bolts out.
    Brought it to us to check out & no amount of shimming or aligning is gonna fix that off idle vib. We did get the bolts to stay in with loctite.
    The stock exhaust is big & heavy for a reason,it helps those twin cyl Yami cancel out the vibration & is only magnified when urathane mounts are used. If you could get some stock Yami rubber mounts it would help.
    I have build a few Blasters that didnt shake till we put a Factory Pipe on it,not as bad as the Yami/Kawi transplants but it def has a off idle vib. Also IMO I believe that driveshaft size has something to do with it as well.
  2. #32
    PWCToday Guru dose's Avatar
    May 2012
    mammoth, ca
    Are you saying it should be worse when riding ? Haven't ridden it with the pump swap yet but is definitely the entire engine shaking making tank,battery, pipe etc shake like crazy just off idle
    Thanks for your input!
    I don't notice the vibration really when im at the lake, when I warm it up I keep the rpms above the rough spot and when you ride its always above the rough spot.
    super couch
    550sx with 701 and big pump
    550 RC-520
    809cc X2
  3. #33
    Jun 2011
    Napa
    what is the weird thing?
    I have the same thing in my yard right now...
    - John Kenneth Galbraith
  4. #34
    Quote Originally Posted by dose View Post
    Some 701's seem to do that. My bros square runs perfect, but right above idle it will shake your nuts off. 100 rpm below and above and it goes away. something harmonic with the motor IMO. just keep it out of that range if you can. Just like grumpy said.
    My friends, same pipe, b-pipe, doesnt. we've ran his up and down the rpm range slow and it wont buzz.
    Edit: Same friend's blaster shakes bad about the same rpm as my bros square, but our last two blasters had no such buzz. stock and B pipe'd blasters didnt buzz, his riva red pipe does.
    freak harmonics IMO.
    1994 1100 SJ - Dead
    1996 spec hx
  5. #35
    Resident Guru rhaas's Avatar
    May 2008
    bay saint louis, ms
    You can make stock mounts fit in the conversion if you want to give that a try. You will need to mill down the engine bed plates to accommodate the taller mounts. You need to mill off about 3/8", you can split it between where the motor mounts bolt to and where the bedplates bolt to the motor. Some of the yamaha motors have a vibration and some dont. The small hull and the light drivetrain make it worse. Give me a call and I can walk you through what you need to do if you want to try the stock mounts. Others have done it with good results.
    RHAAS PRODUCTS
    urethane motor mounts for watercraft... its about time!!
    http://www.facebook.com/#!/pages/Rha...12717472096935
    try our new website
    http://www.rhaasproducts.com/
    stay tuned for more products
  6. #36
    Mar 2005
    Santa Barbara, Ca.
    Quote Originally Posted by rhaas View Post
    Well I went with new stock SJ mounts and 90% of the vibration is gone... acceptable now for sure. I machined the Yamaha bedplates .200" where they mount to the engine and another .200" where they mount to the motormounts. Some creative milling setups I must say Completely changed the vibration to nearly nothing.
    Thanks Robin for all the support!
  7. #37
    Jun 2011
    Napa
    so i rode a blaster 1 this weekend with a 701 and FPP. OFF IDLE VIBRATION... Fresh rebuild, perfect alignment, it is something with the yamahas.
    it wasn't as bad as my x2 but still there. On a positive note I just squeaked my 701 in my x2 prepping it for pismo this coming weekend. now in a mad rush to get the new motor assembled and in b4 i go!!!!
  8. #38
    Mar 2005
    Santa Barbara, Ca.
    Quote Originally Posted by cudaben View Post
    Hey... Might just stop by... Is Mark going?
