Results 21 to 30 of 38
    PWCToday Guru dose's Avatar
    May 2012
    mammoth, ca
    Re: Yamasaki vibration ??
    So SJ OEM mounts will fit in the Rhass conversion kit? I was under impression it used custom height mounts. Humm... thanks
    I also thought the mounts were custom size/height/angle for the kawi to yami conversions.
    super couch
    550sx with 701 and big pump
    550 RC-520
    809cc X2
    Chicago / Portage, MI
    Interesting to hear removing the stock Yamaha exhaust will increase vibration. I'm not sure how that plays in other than weighing less it will be easier for the engine to move around. I did feel increased vibration on my WJ650 when I took the stock pipe off, but I'm almost positive that was an alignment / shimming issue. It would be worst right above idle and then it would go away as the engine climbed in revs.
    I have also seen on a few skis that you can have weird harmonic vibration with the impeller hitting the wear ring. Sometimes this causes vibration all through the rev range, and other times it's at very specific spots. I currently have a bit of that on my jammer because it's a mixed flow pump and it's shimmed very tight to the wear ring to reduce the chance of cavitation.
    On some I've spent a huge amount of time with coupler / engine alignment. With the SX hulls it's so much easier with the floating mount and that becomes no issue.
    It does seem with the 550 hulls that the Rhaas kits install differently. My thought is the bulkhead surface the pump shoe bolts to might have a pretty loose tolerance from the factory, or maybe this changed slightly over the years and with various molds. I had to work for a while initially on properly setting mine up so the impeller wouldn't rub and the gap between the pump face and shoe face was minimized. My final setting had a bit of a gap, which I filled with epoxy putty and sanded smooth.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
    Michigan
    Still hard to believe that all the Superjets out there with aftermarket exhausts vibrate like this. My Kawasaki based twins sure don't. Must be a combination of things to make it happen.
    Thanks for all the replys!
    I have two Superjets with an aftermarket Factory B Pipe and other mods.. One is a Square and one a Round Nose.. I have no such vibration at any RPM..
    Mar 2005
    Santa Barbara, Ca.
    Quote Originally Posted by JSNate View Post
    Nate ... are you running stock mounts??
    Dec 2009
    Buffalo
    I finally fixed my running issue this evening and noticed I do have a vibration off idle as well just on the stand I could tell...
    Wait till you ride it.
    Dec 2009
    Buffalo
    I'm pretty pumped to ride it, honestly though what can come of the vibration if it's just at one spot in the throttle? Is it a huge deal? My 550sx/650 kawi conversion had a vibration but ran awesome and never really was bothersome.
    Michigan
    Yes.. Stock, Yamaha OEM mounts.
  9. #29
    Mar 2005
    Santa Barbara, Ca.
    Are you saying it should be worse when riding ? Haven't ridden it with the pump swap yet but is definitely the entire engine shaking making tank,battery, pipe etc shake like crazy just off idle
    Thanks for your input!
  10. #30
    Mar 2005
    Santa Barbara, Ca.
    See if this works...
    Attached Files Attached Files
