Results 11 to 20 of 38
    Re: Yamasaki vibration ??
    Rhass builds some nice stuff & I am not knocking his products but urathane motor mounts are a LOT stiffer than rubber & will cause more vibrations.
    Back in the day (early 90s) Triton made urathane motor mounts & I installed a set in my otherwise smooth Seadoo & it had vibrations that would vibrate thru the hull badly.
    IMO the Yamaha twins without the heavy stock exhaust are gonna vibrate & add the skinny azz Kawi drive shaft & you are gonna get that off idle vibration.
    Dec 2009
    Buffalo
    Guess it makes sense, I was just curious
    Mar 2005
    Santa Barbara, Ca.
    Still hard to believe that all the Superjets out there with aftermarket exhausts vibrate like this. My Kawasaki based twins sure don't. Must be a combination of things to make it happen.
    Thanks for all the replys!
    PWCToday Guru dose's Avatar
    May 2012
    mammoth, ca
    Im building a yamaha powered X2 for the summer using the RHASS kit. Even if it shakes like my 550/701 it will still be worth it. I love the Yamaha power in kawi hulls
    super couch
    550sx with 701 and big pump
    550 RC-520
    809cc X2
    They dont have Rhass mounts & a skinny like a twig driveshaft.
    Jun 2011
    Napa
    Rhass has addressed this- he now offers 1/8" and 1/4" shorter SJ mounts. I think its a combintion of stiff mounts, and if you are running the stock SJ height mounts then the angle of the motor and the angle of the driveline being off just a smidge. I have some odd wear on my fancy aluminum DS coupler. This is my theory! I have not manned up to buy a set of OE SJ mounts- and BTW OE Yami couch mounts are slightly taller than SJ mounts so thats out, I did buy a used set of those.
    One thing to watch for is super acceereated prop wear.
    I have gone through a few props with my setup. I rebuilt a pump new bearings and seals, did a stuffer, and new impeller. It clanged around in the housing, just the same as the junk ones I tossed together to get on the water.
    - John Kenneth Galbraith
    Mar 2005
    Santa Barbara, Ca.
    So SJ OEM mounts will fit in the Rhass conversion kit? I was under impression it used custom height mounts. Humm... thanks
    Dec 2009
    Buffalo
    Well I'm going to be running the old style driveline not the sx so I am now curious to see if the vibration is there.
    Mar 2005
    Santa Barbara, Ca.
    I am thinking of taking some 550 2 piece mounts and machining some new wedge bases to fit the Yamasaki set-up. There are tons of 550/750 conversions using 550 mounts without the vibrations so why not try it on the the Yamaha?
    Or try and modify a 550 bedplate to fit a Yamaha with a conversion plate?? This must have been tried...
    Riverside, CA
    6
    Seems to me the stock Yamaha subshaft, bearing support, and
    the bulkhead would dampen some of the vibration.
    The Kawasaki driveshaft being solid is just going to amplify the
    vibration, and prevent the same dampening the Yamaha coupler
    and sub shaft would provide.
