Results 1 to 10 of 17
    PWCToday Guru Rconce01's Avatar
    Mar 2007
    miami
    Blown fuse 5amp on MPEM 94 seadoo xp
    I'm working on this ski that sat for a long time I got it to start up but after a couple minutes completely died. Now it keeps blowing the 5amp fuse. So far from what I gathered it can be the inductive coil the magneto or a Bad MPEM. Can a VTS issue cause this fuse to blow consistently as soon as the battery is connected?
    Resident Guru Bionic racing's Avatar
    Idaho/California
    Re: Blown fuse 5amp on MPEM 94 seadoo xp
    Have good MPEMs if needed
    Mar 2007
    miami
    Cool I need to see if it's the MPEM first. Do you have fuel pump on the 657 carbs? I need that for sure.
    Idaho/California
    Plenty of that stuff , scraped out 5 657s last year
    You need a new MPEM.
    Mar 2007
    miami
    I can swap one of the other ski since it's a pair. How can I know that whatever cause the failure won't fry the other MPEM? Is there a way to test for sure it's the MPEM?
    I read something about disconnecting the yellow wires and then the red wire
    Idaho/California
    Sounds like your disarming a bomb on a movie , just don't cut any wires
    Mar 2007
    miami
    Pm sent
    Feb 2002
    Vancouver, BC Canada
    I agree.
    Quote Originally Posted by Rconce01 View Post
    I can swap one of the other ski since it's a pair. How can I know that whatever cause the failure won't fry the other MPEM? Is there a way to test for sure it's the MPEM?...
    You need an MPEM. Remove the MPEM and test for continuity between the 5 amp fuse and a ground wire coming from the MPEM. There should be no continuity.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Mar 2007
    miami
    I agree.
    Chester
    Thanks im checking it out tomorrow and will report back what i find
