Hydrospace swap
Results 1 to 8 of 8
Thread: Hydrospace swap
    Nov 2011
    alberta
    Hydrospace swap
    Since i cant seem to sell my hydrospace, im trying to start preplanning for an engine swap for when the stock motor eventually goes. I am thinking 951 or 1100 but cant find a ton of info on how each actually rides, ive heard the 951s handle a bit better but seem to he alot less around, the 1100 would be easier from the sounds of it but i havent heard much on ride quality. Any opinions on either swap or other options to do with the ski? Any input is appreciated, thanks!
    Oct 2013
    funky town
    Re: Hydrospace swap
    I have a fresh 951 in an 01 xpl. Less than 30 minutes after completing 3 heat cycles for break in.
    I'm only here to make you mad
    Frequent Poster kotarbi's Avatar
    Jan 2003
    san antonio tx
    Re: Hydrospace swap
    I would go with what ever power plant your more comfortable. I have a 1100. Friend has a 951. Not a whole lot of diff to me. Either way we had to add weight to to front to balance out
    My ski favored the left bad and would hook and do crazy stuff until I added weight I put 20lbs on the right side and 5 down the middle. I experimented with ankle weights until I got it where I wanted.
    07 Hydro Triple!!
    06, 07 SXR's
    93sx-Pro
    85,87 wetbikes
    Nov 2011
    alberta
    Re: Hydrospace swap
    Thanks, definetely know 1100s better, had one in a bullet v2 but it burnt, probably go that route then, appreciate the info on the weight addition also.
    Oct 2013
    funky town
    Re: Hydrospace swap
    It's so cool to get real info from dudes who have done it. Makes life easier.
    Nov 2011
    alberta
    Re: Hydrospace swap
    Definetely! So hard to find info on skis sometimes, nothing beats first hand experience.
    PWCToday Guru jimmy w's Avatar
    Dec 2002
    florida
    Re: Hydrospace swap
    hydro-doo all the way
    PWCToday.com Is My Home Away From Home sxr951's Avatar
    Aug 2007
    Mecong Delta, Florida
    Re: Hydrospace swap
    didn't add any weight at all.. on my 951 w rossier pipe. best turning ski I ever rode.. can go wide open w eyes closed tracks straight a flaming arrow!
