Weld cadt aluminum?
Results 1 to 10 of 16
    Mar 2017
    Odenville, Alabama
    Weld cadt aluminum?
    Found why i suspect the venture is running rough.....shes breathing her own fumes......i think the exhaust is14923663436551075464650.jpg14923663436551075464650.jpg cast aluminum....right? Weldable or cheaper to just replace?
    Re: Weld cadt aluminum?
    Given the price of used parts right now I would just replace it, with all the oil and gas that has gone through that pipe it will be a b!tch to weld.
    WWSRD , What would Speed Racer do ?
    PWCToday.com Is My Home Away From Home hyosung's Avatar
    Aug 2010
    Australia
    JB weld
    http://www.pwctoday.com/showthread.php?t=425767
    modded X2 650
    900 powered custom 650 sx .
    Jerry Rigging is my specialty .....
    if i did like everyone else and copied everything i needed or wanted i would save lots of time and money.
    Mar 2017
    Odenville, Alabama
    It just keeps getting better..........friggin 2nd hand skis
    Frequent Poster Dave in DE's Avatar
    Apr 2016
    slower lower Delaware
    +1 on the j- b weld. Clean it good with a wire brush and and carb cleaner or MEK. MEK preferred. Patched a 5 inch crack in a Kubota diesel block with JB a few years back. Still holding strong.
    Aug 2010
    Australia
    even better belzona!
    modded X2 650
    JB weld will give up the ghost after a while, I have done several quick and dirty repairs on Seadoos with blown out welch plugs on the head pipes, JB works for a year or so but eventually it always lets go, I can almost assure you when it lets go it will be at the most inconvenient time possible.
    PWCToday.com Is My Home Away From Home don37725's Avatar
    Jan 2006
    Smoky Mountains TN
    Quote Originally Posted by Omega5677 View Post
    Daaaaammm Yamaha - Only 20 yrs old and problems already - Nice time of year for a road trip to the Smoky Mountains
    Democracy is two wolves and a lamb deciding what to have for dinner***
    *******************Liberty is a well-armed lamb.*****************
    **********Lotteries are created by those who understand math**********
    ***************to take advantage of those who do not****************
    ***************As government expands, liberty contracts**************
    Quote Originally Posted by don37725 View Post
    Daz clean azz shizz
    The corrosion ate that thing from the inside out. Ridden in saltwater and never flushed.......nice!
