Results 1 to 6 of 6
    Jan 2017
    Missouri
    787 Aftermarket Parts for 951 Parts
    I am selling or trading my 787 stuff for 951 stuff. Will need full 951 motor w/white pipe, xp mounts, hump seat, larger x4 fuel tank setup, 155 plastic pump and so fourth. If you have some of these parts and are interested in some trades just hit me up. Willing to work something out to get going on my project. Thanks
    636-two36-5936
    Buckshot Carbs - Includes all internals however currently broken down as I cleaned them out inside. One has a purple intake piece one is silver, other than that they are identical.
    $250 shipped
    Buckshot Intake - Has the oil injection fittings if you choose to run the oem oil pump.
    $100 shipped. Combine with carbs for $325 shipped
    West Coast Head - 43cc domes. Looks like its never been ran, domes are fresh as they get, domes remove easily. Good pump gas head.
    $300 shipped
    PSI Single Pipe - Includes all jets, fittings, hoses, gaskets, instructions and hardware. Looks like its never been ran. $400 shipped
    PSI Twin Pipes - Tapped for EGT guages, pressure tested from previous owner. Includes all mounting hardware and bolts. $375 shipped
    TRD Exhaust - Used trd exhaust, no water reg port, $125 shipped
    WestCoast Nozzle w/ring insert - Believe this is made by WC. Ring is 85mm pump side and 89mm exit side. Just this one nozzle/ring included. $150 shipped
    Misc Filters: Offer
    Willing to work out prices for someone that is buying multiple items. Eager to get going on the new build. Everything I ship is insured and packaged properly.
    PWCToday Guru crazycalito330's Avatar
    May 2013
    Lake Sonoma, California
    Re: 787 Aftermarket Parts for 951 Parts
    Did I miss the trd exhaust picture? Interested
    Sent from my SM-N910V using Tapatalk
    Jan 2017
    Missouri
    Quote Originally Posted by crazycalito330 View Post
    Would you be interested in a 155mm 10 vein GTX pump? Stainless center, setback 1 inch, only came on 4tec 02 model.
    Jan 2017
    Missouri
    Sorry thought I replied already. I bought a pump
    Feb 2012
    Bluffton / HHI, SC
    PM me... i have two GTX 951 skis im looking to part out
