Results 11 to 18 of 18
    PWCToday Guru TaintlessEd's Avatar
    Oct 2016
    Lake Elsinore
    Re: 2008 ultra 250x help
    Ok see the starter solenoid next to the battery,pull the black covers back & jump those terminals with a screwdriver & see if it turns over.....
    Make sure the battery terminals are tight,not screwdriver tight 10mm wrench tight.
    When I use a driver to do what you said nothing happens. When I jump it straight from the battery to the top post of that box next to the battery the engine turns but very slow.
    Sin City USA
    You must check your grounding connections as well, a loose ground connection gives the same symptoms as a loose positive.
    Or the motor is shot,which wouldnt surprise me either.
    Oct 2016
    Lake Elsinore
    It's the neighbors ski and he's about 60 so I was trying to help out. I told him to send it to the shop and let them play with it because I can't figure it out. I'll post what the problem was when it comes back in a couple days.
    Oct 2016
    Lake Elsinore
    The shop said all they did was replace the plugs. They said the plugs were bad. Not fouled but actually faulty...
    charged my neighbor 550$ and he flipped, they worked it down by a hundred and some change but that's still highway robbery.
    The supercharged skis tend to eat a set of plugs every 20-30 hours.
    Aug 2010
    Australia
    im calling BS!, there is no way the spark plugs can cause the symptoms you quoted , maybe ? it was rusted up in the bores and they sprayed some WD 40 in the plug holes and it freed up ???? . or they simply found the bad ground ???
    modded X2 650
    Originally Posted by hyosung
    Oct 2016
    Lake Elsinore
    Quote Originally Posted by hyosung View Post
    I mean, you can call BS all you want.
    Why would a shop tell you they only did a certain amount of work but in reality did more?
    When I asked them what they did they said they changed out the battery( I tried 3, two brand new , known good batteries, and a charged used one) he said after he did that he was able to get it started so he took it out.
    He told me it only went 35 and he couldn't get it to go any faster.
    He ordered spark plugs, replaced them, ran the ski and he said it ran fine after that.
    Take it for what you will/want. If they did more to fix it the issue they didn't mention it.
    I'm pretty confident in the shop because I live less than a mile away and I ride and drink with one of the mechs.
