Results 1 to 10 of 18
    PWCToday Guru TaintlessEd's Avatar
    Oct 2016
    Lake Elsinore
    2008 ultra 250x help
    It has 24 hours on it and won't start.
    The fuse in the orange box is good.
    I slide the key in and it doesn't beep all the time, just sometimes. When it does it beeps a ton of times saying the battery is dead(it's not dead, it's new, like just bought it new).
    When the beeping finally stops you go to hit the start button and everything just shuts off.
    After playing with it I think I narrowed down the issue to these two boxes but I can't find replacements anywhere for the life of me. I download all of the exploded views and diagrams for the ski and can't find them in there either for a reference or part number.
    Re: 2008 ultra 250x help
    Ok see the starter solenoid next to the battery,pull the black covers back & jump those terminals with a screwdriver & see if it turns over.....
    Make sure the battery terminals are tight,not screwdriver tight 10mm wrench tight.
    Oct 2016
    Lake Elsinore
    I'm at kokomos right now but when I get home this will be the first thing I try and I'll report back.
    Thank you for that. I can't believe I didn't think of that.
    Aug 2010
    Australia
    you have a loose terminal , the boat should still be warrantee so back to the dealer ,they will probably fix it under good will if it is out of warantee ..as grumpy said try jumping the terminals ""BUT""" a solid one hit connection is needed or you can serge the ECU>>
    modded X2 650
    Originally Posted by hyosung
    Feb 2002
    Vancouver, BC Canada
    As said, you have a loose connection somewhere. Start tracing circuits.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Aug 2007
    http://fiche.worldofpowersports.com/...FUEL-INJECTION
    21175a for the ecu
    27002 for the relay
    Not saying this is your issue, but you were looking for a reference to those parts.
    Oct 2016
    Lake Elsinore
    I jumped the relay and not a damn thing happened. What now?
    Top Dog aggrovated's Avatar
    Frozen Tundra, MN
    Not that this is your issue.
    I have a similar issue with my 2010 260x, but I took mine into the dealer. They jumped the relay and it worked. So they're ordering a new relay.
    Apparently, they're notorious for failing.
    Oct 2016
    Lake Elsinore
    https://jetskiparts.com/products/kaw...-250x-1100-stx
    This?
    That will fix the problem of the gauge cluster/beeps being seldom and intermittent?
    When I plug the key in all I hear is a very faint click and there's no beeps or anything.
    Quote Originally Posted by TaintlessEd View Post
    If you jumped across the 2 big wire on the starter solenoid & it did nothing......bad battery,bad starter,bad ground
