Do not buy SBT flywheel pullers
Results 1 to 2 of 2
    Top Dog bandit88's Avatar
    Green Bay WI
    As the title states, do not buy SBT flywheel pullers. I had gone to replace the crank seals on my 750 this past weekend. Had a brand new SBT flywheel puller that I pulled out of the package minutes before using it. The threads in the puller were so soft that it didnt take much for them to strip out leaving me with the puller stuck in the flywheel. It took about a hour but I finally got it removed but once removed, the threads in the flywheel were destroyed. Had to pull the whole motor apart to be able to press the flywheel off the crank. So now im left with a junk flywheel and a even junkier puller. Ive always defended the quality of SBT cranks and have got a top end kit in the past. No more, if you cant make a quality hardened bolt, you cant make a quality crank. This was about my 10 motor rebuild, never had a issue pulling a flywheel before. Buyer beware.
    -95 750SXI
    -90 TS650
    -91 300SX
    Sep 2010
    Kent, WA
    Re: Do not buy SBT flywheel pullers
    I also bought a 750 flywheel puller from them. I can agree the metal is softer than it should be. The threads were visibly damaged after I used the tool. Fortunately, for me it did work, and I only needed it once.
    Regards
    charger_john
    in Kent, WA.
    1996 JS750SXI (sold in 2017!), 2004 STX-12F, 2015 Superjet
