Tigershark 1100 crankshaft
    Jun 2004
    Lansing, MI
    SBT, can you rebuild my Tigershark 1100 crankshaft? I only see the 1000 listed on your website. My understanding is the only difference is the rods (longer stroke) between the 1000 and 1100.
    98' Sea Doo SPX Mint
    96' Sea Doo HX Mint
    95' Sea Doo XP800 Mint
    My Jet Ski videos below.
    Oct 2013
    Ohio
    Re: Tigershark 1100 crankshaft
    I would be uncomfortable sending SBT a Tigershark crankshaft. They might be good with other brands, but I do not think they do enough of them to know what they are doing or to have the correct parts on hand. They assembled the 770 engine I bought from them using incorrect parts on the crank, which led to engine failure after the warranty expired.
    Even though the parts were obviously incorrect, they would not even discuss the issue in a meaningfull manner.
    The only advantage you have is you will be able to see and inspect the crank as soon as you get it. I was unable to disassemble and inspect the engine I bought or the warranty would have been void.
    Jun 2004
    Lansing, MI
    Do you have pictures of the "incorrect parts" they installed? What incorrect parts did they use that caused your engine to fail?
    I have never bought a SBT engine but have used their cranks and pistons in the past and have had nothing but great things to say about them. I have checked every crank we have bought from them and the tolerances have been tighter than ones coming from the "better" rebuilders.
    96' Sea Doo HX Mint
    Oct 2013
    Ohio
    I fully documented the situation very carefully. It is all here. http://www.pwctoday.com/showthread.php?t=467547
    In addition, I contacted SBT prior to making this public to give them a chance to respond properly. Their response never addressed the fact that they had used incorrect part. The response, simply paraphrased here;
    "The engine is out of warranty, it is unfair to blame SBT as there are many things than can cause engine failure."
    I certainly understand that mistakes can happen. Their failure to intelligently discuss the situation, even though the engine was out of warranty is unacceptable.
    Many people here have good luck with them. I have used their parts to rebuild another engine and had no problems. But if you do some research, you will find others have issues also...
    http://www.greenhulk.net/forums/showthread.php?t=98482
    http://forums.iboats.com/forum/gener...-of-sbt-motors
    Some people like them. If they had actually addressed the issue properly, instead of providing such generic response, I would feel differently.
    PWCToday Regular SBT-Tech's Avatar
    Clearwater Florida
    SBT does not do this crankshaft because of the limited number of them in the field, and because we do not have a good source for the connecting rods.
    Quote Originally Posted by Dan87951 View Post
