2005 Yamaha vx110 deluxe question
Results 1 to 8 of 8
    PWCToday Newbie jash1178's Avatar
    Apr 2016
    North Carolina
    Is there is way to power up the dash to read hours meter without starting the engine?
    Sent from my Samsung Galaxy S7 Active.
    Jul 2015
    Columbia, SC
    Re: 2005 Yamaha vx110 deluxe question
    I know on my FX you can put the key in (or just lift up the starter) and very quickly just tap on the start button. It won't engage the motor and will be enough to turn the digital screens on
    Apr 2016
    North Carolina
    Hmmm ok. Thanks!
    Jul 2015
    Columbia, SC
    Also depending on the ski - if its a 4stroke it should take at least 1-2 secs before the motor actually turns over. so should give you just enough time to get a reading before it turns over.
    Or just go ahead and hold the kill button while you crank just a second or 2.
    Apr 2016
    North Carolina
    Infinity you were exactly right. I pushed starter button very briefly and it came on. I just bought it, it's got 79.2 hours on it.
    Apr 2016
    North Carolina
    Quote Originally Posted by jash1178 View Post
    Infinity you were exactly right. I pushed starter button very briefly and it came on. I just bought it, it's got 79.2 hours on it. Is that good for an 05 Yami?
    Mar 2017
    USA
    Thanks for the info. Was dealing with this issue myself.
