Honda Jetski ECU - Page 8
Page 8 of 8 FirstFirst ... 678
Results 71 to 77 of 77
  1. #71
    Apr 2018
    PA
    Re: Honda Jetski ECU
    Quote Originally Posted by Gen-Tune View Post
    Below is a Turbo fuel map compared to a Non Turbo fuel map. Looks like there are 4 fuel maps. I assume for different cam angles.
    RED = Turbo
    Blue = Non Turbo
    That's really cool! Are the 4 maps similar? Maybe it has a table for each cylinder. Also, I'm surprised the numbers differ so much Turbo to non Turbo. There must be some other constants that are also changed.
  2. #72
    I dream skis jlfx car audio's Avatar
    Feb 2011
    jackson tn
    I figure the fuel tables are for knock control . or temp . these skis dont have adjustable cam timing so thats not it .
    Or the 4 tables could be for each cyliner if they designed them to be fuel differently based on individual cylinder temps
    05 R12x 142hrs w/ ic upgrade,strait pipe ,stock prop and boost 6380rpm @66.2mph
    09 F15x 39hrs .
  3. #73
    Feb 2017
    Florida
    There are more Fuel tables but only 8 tables show differences compared to a non turbo map. I doubt they will have a complete fuel table for individual cylinders. I'm sure its probably for either different degrees of timing or water temperature since these skis are open loop. I could be wrong but I dont think I'll spend the time to dig too much as the market is slim and not alot of request.
    I'll have to do some wideband testing.
    Having the non turbo map made this process much easier to isolate the differences.
    Right now I am working on 4 different things
    - Revlimiter
    I may have found the location that controls the revlimiter just gotta do some testing
    - Disabling the secondary map sensor that measures pressure from the turbo
    I found the routine that enable/disable this sensor. Need to do testing.
    - PWM boost control
    I've located the code that controls the solenoid. Goal is to bleed off more boost pressure to keep the wastegate closed longer.
    - Fixing the 2002-2003 model ecu's. There is a slim chance I can fix this ecu as it's much different.
    I would like to take a look at the F15x ecu's if anyone has one broken and willing to donate for research and development let me know
  4. #74
    Jun 2003
    JACKSONVILLE FL.
    I am not sure there are any failed F15 ECUs available since they seem to be bullet-proof.
    Honda Pilot NAVI
    F150 4x4
    3 '06 F12Xs
    CR250
    2 CR80s
    1 XR100
    2 PW50s
    1 Vento Phantom 150
    1 Honda SHI 150
    Jax. Fl.
  5. #75
    Feb 2017
    Florida
    - Revlimiter
    - PWM boost control
    If Anybody is looking to get this done email me at fireball2244atgmail.com.
    I've done over 250+ ecu's with no issues. 100% fix rate and saved many thousands of dollars. Ive helped many member's here who can vouch for my work
  6. #76
    Feb 2017
    Florida
    Guys a further update. I've been working on the 3 plug ecu that comes in the 2002 and some 2003 models. Hopefully I'll have something soon.
  7. #77
    May 2019
    Claytor
    Has anyone tried this ?
    Would the jetski work w/ the motorcycle ecu ?
