Sxr Ultra! 1200 - Page 2
Results 11 to 20 of 30
Thread: Sxr Ultra! 1200
    Cypress, TX
    Re: Sxr Ultra! 1200
    What's going to happen to the front motor mount tab? Will it clash with the OEM fuel tank? What's the plan for the hacked bulkhead?
    The 951 Seadoo engine has slant pistons and runs great...with a counter-balance shaft...
    Re: Sxr Ultra! 1200
    Quote Originally Posted by pro785 View Post
    I've been watching this thread, it's an interesting build. I want to see how it runs and if those pistons being sideways will do something weird with how it rides. I always kind of wanted to see this happen, keep updating us.
    uhh... go look at some ultras or stx-r 1200s.... this is how the 1200 is designed. this motor runs like a four stroke, vibration wise, it has 2 separate counterbalancers.
    front motor tab is going bye bye, the custom motor plate underneath is the sole reason so i can get the tank up front.
    just in case no one knows these 1200 motors, this has 2 counterbalancers.
    1994 1100 SJ - Dead
    1996 spec hx
    Re: Sxr Ultra! 1200
    Looks like *ss. Not the good kind, but pleeeenty of penetration and no porosity.
    decided to NOT tig it, this part is 0.045", just built it up and out with a spool.
    1994 1100 SJ - Dead
    1996 spec hx
    Sep 2007
    Utah
    Re: Sxr Ultra! 1200
    did you ever finish that triple pipe HX you were building?
    Re: Sxr Ultra! 1200
    Yep it was a turd. Only ran 62 but I never got it up in the pupes. Combination of deep v, lotsa weight up front, and a small pump tunnel for a 155 pump made it suck.
    1994 1100 SJ - Dead
    1996 spec hx
    Sep 2007
    Utah
    Re: Sxr Ultra! 1200
    Quote Originally Posted by 88kawi5fiddy View Post
    hrm, so less is more. I'm almost done converting my HX to a 91mm 951 w/Rossier pipe, Novi 46s, etc etc.
    Re: Sxr Ultra! 1200
    im sure the 961 is lighter by probably a 1/3 ish, and since that weight is less forward it'll work like its supposed to. the dry pipes are also 14 lbs a piece, so they arent heavy.
    1994 1100 SJ - Dead
    1996 spec hx
    Jun 2013
    Fort Wayne Indiana
    Re: Sxr Ultra! 1200
    holy moses I hope this build gets finished.
    Oct 2013
    funky town
    Re: Sxr Ultra! 1200
    Quote Originally Posted by Blairwill4 View Post
    I just want someone to stop by with some grilling meat. I hungry as fuk, and I'm not gonna take it much longer.
    Those cheese filled brauts are good....
    I'm only here to make you mad
    Top Dog
    Dec 2007
    WI
    Re: Sxr Ultra! 1200
    Only in Wi. do we put fat in fat to eat! Is this build done?
