Sxr Ultra! 1200
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Sxr Ultra! 1200
    Sxr Ultra! 1200
    Laserjet is on indefinite hold for awhile, school, lack of money (that I want to sink into a 550 hull), working on on a desert go-fast jeep, and this POS will keep me busy for awhile. The laserjet also needs to be fully separated and reglued.
    I was bored, I dont want to put a twin back in this sxr. Took a trip to cali and picked up two ultra 150s and a pro 785.
    I have a solas 148 mag pump i may or may not do a setback with...
    Deepened and started straightening out the bottom, still has a little work left but most of it is done. Messenger sends crappy pics, sorry.
    20170222_113356.jpg16650866_10202925000883064_1912369336_o.jpgIMG_20170203_172608.jpg
    I've only seen 1 other with an ultra motor in there, and it was tight. It should fit fine.
    I don't really want the triple AND a forward water box up in there, but I don't see any room for the waterbox anywhere else.
    1994 1100 SJ - Dead
    1996 spec hx
    Re: Sxr Ultra! 1200
    Pump and driveshaft are in.
    Half of the new motor plate is built
    1994 1100 SJ - Dead
    1996 spec hx
    Cypress, TX
    Re: Sxr Ultra! 1200
    Like your creative work and talent.
    I assume you tack-welded the first half of the new motor plate in position? And you clamped the negative ground welding lead to the top crankcase bolt? If that is so, please inspect your crankshaft bearings for damage...
    The 90+ amps of current used for tacking the motor plate in position will likely have traveled thru the crankshaft bearings and damaged them...
    Re: Sxr Ultra! 1200
    Spare crank and cases. Half the chit is rusted. My real one is on the bench
    1994 1100 SJ - Dead
    1996 spec hx
    Re: Sxr Ultra! 1200
    just one guy likes my janky skill? come on yall its spring time, time to wake up and either troll me or tell me you wanna ride it when done.
    motor is in, i started welding the pipe today. cast to 6061 sucks.
    1994 1100 SJ - Dead
    1996 spec hx
    Top Dog RIDEH2O's Avatar
    Jun 2011
    nevada
    Re: Sxr Ultra! 1200
    Im watching....
    waiting to see how the exhaust fits in there.....
    2017 Jet Jam Racing "Region 2" Sport GP Champion
    Thanks 2017 sponsors....
    Lets do it again in 2018
    Reno KTM
    DirtTricks
    Reno / Tahoe Watercraft Connection
    Hunt & Sons / VP Racing Fuels
    Garate Enterprises (The Powder Man)
    On the Mark Construction, Reno NV
    Re: Sxr Ultra! 1200
    Got 'er welded up. not the prettiest but definitely has fullpenetration and no pinholes.
    Going to finish the 90 degree turn with TIG and new stinger and 2 spray nozzles tomorrow.
    1994 1100 SJ - Dead
    1996 spec hx
    PWCToday Guru josh977's Avatar
    Feb 2008
    Cincy, OH
    Re: Sxr Ultra! 1200
    Looking good, aluminum is a pain in the *** to tig. Cast AL is like a sponge to dirt n grime.
    '04 SXR
    '96 SeaKaw HX
    Aug 2010
    delavan, wi
    Re: Sxr Ultra! 1200
    I've been watching this thread, it's an interesting build. I want to see how it runs and if those pistons being sideways will do something weird with how it rides. I always kind of wanted to see this happen, keep updating us.
    90 Superjet, 98 Polaris Pro 785, 95/92 Kawasaki 750 sxi, 01 Polaris 600 sc xp
    Feb 2008
    Cincy, OH
    Re: Sxr Ultra! 1200
    My 01 ultra always ran and performed spot on. The oem carbs were hard starting @ times.
    '04 SXR
    '96 SeaKaw HX
