Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
    SE MI
    Re: Westcoast Themed 550
    No problem, if I find it ill post it here.
    Sep 2005
    AZ
    Do you (or anybody) have any literature on these?
    See attached.
    Attached Files Attached Files
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust.
    Frequent Poster J_shamper's Avatar
    Jul 2014
    IL
    Interested in a hood as well if your guy feels like making a run of them.
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    See post #11 for a Westcoast catalog.
    http://www.pwctoday.com/showthread.php?t=304264
    Sent from my XT1650 using Tapatalk
    - 03 Superjet - 1mm over bore, hooker 9/15, destroyer tubbies, carbon ride plate, cold fusion turn plate, quick steer mod, UMI bars, blowsion pole spring, jetmaniac girdled head, limited chamber b pipe
    - 94 WB1 - protec ride plate and top loader, 61x61x (FOR SALE)
    - 92 550sx - under construction
    - SNSJ - dual 44sbn, protec girdled head, 735cc, 62t61x, cylinder ported by tim tynan, protec exhaust, bored nozzle, 10/16, worx 201 top loader
    Top Dog
    Sep 2008
    San fran bay area, ca
    About the only thing I was able to do is relocate ski to work area and pull the fuel lines and tank.
    90' 550SX "Shaved head, .5mm+ Wiseco pistons, SBN 44, Kerker exhaust, Mariner waterbox, WestCoast OS Gas Tank, extended ride plate,(440 pump) 16deg SS Skat imp."
    WIP - 83' JS550 " .5mm+ Wiseco pistons, WestCoast: Head, rc520 reed cyl, 7 Ring Exhaust, Ext Ride plate, Ex Manifold, 2x Velocity stack, waterbox, Westcoast Dual 38 intake, Dual SBN 38s, 440 pump and a 16.5 degree SS Skat imp. Lightend flywheel"
    97' Tigershark Monte Carlo 1000 fresh top end and runs finally!
    Top Dog
    Sep 2008
    The house search is taking up most my time. I did get to work on it a little Friday. I basically pulled the engine out. All I can say is geez it is so dirty In There. And engine has corrosion on it. Gonna need to clean motor and hull good.
    Hopefully it cleans up nicely. Any tips on cleaning up engine components? I also need to grab some thick stainless washers and chrome acorn nuts.
    Top Dog
    Sep 2008
    i've forgotten what size the head bolts are , cant remember if they m8 or m6
    Top Dog
    Sep 2008
    Any one?
    So I got my stuff back from Chris Newmiller today it's clean. I'm gonna paint the flywheel red so it won't rust. Tomorrow night I'm going to TRY and assemble the westcoast motor if the paint drys, isn't it'll be Wednesday or Thursday.
    Top Dog
    Sep 2008
    Also ideas Please on color. the head, Exhaust pipe, Waterbox are blue*, starter and Mounts are red* Cylinder, Intake, Exhaust Mani are Silver* Cooling lines are Most likely gonna be red and Fuel lines Blue.
    Whats left are the E-Box, Bed Plate, Fly cover, and Cases that need paint. Any sugestions?
    * already painted
    PWCToday Regular jshlee3's Avatar
    Apr 2016
    Colorado
    I'm doing a similar project and purchased a $100 bench grinder style buffer on Amazon to polish all my Aluminum parts to a chrome like finish. Its a lot of work but they look pretty sweet when they are done. So far I have done the ebox, fly wheel cover, ex. mani, pipe and plan to do the cylinder and possibly the case. There are a lot of photos in the vintage PWC gallery to give you ideas. The pictures below are the look I'm shooting for... I think one of the picture is from Mr. Ski westcaost build.JPG IMG_1273 (1).jpg
