Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
    Top Dog
    Sep 2008
    San fran bay area, ca
    Westcoast Themed 550
    This will be my second build, Also I'm not going to be able to update this as frequently as I would like because I only have maybe a day a week to work on it. here is list that's going into it:
    - Westcoast RC520 Race Cylinder
    - Westcoast Bulkhead Brace
    - Westcoast Dual 38 RC Reed Intake
    - Westcoast OS Tank
    - Westcoast Head
    - Westcoast 5 ring Full exhaust(thinking about a 3 ring cone for better top end)
    - Westcoast Velocity Stacks x2(38s)
    - Westcoast finned rideplate
    - Westcoast Exhaust Manifold
    - Westcoast waterbox
    - Westcoast Bilge relay
    - Dual SBN 38s
    - Welded Crankshaft
    - Lightened Flywheel
    - Skat-Trak 16 (on a 550 pump)
    - Tap Pump for Dual Cooling
    - 500 gph Bilge
    Hull mods
    - Hull Braces
    - Convert from nose Ex to rear Ex
    - Tubbies
    - Glass over fuel filler and nose ex
    - Set hull up for Dual Cooling
    - Westcoast hood...at least I think it is
    couple pictures of some of parts
    IMAG0310.jpg16900420_1559516040743714_599583161_n.jpg16831129_1563462133668046_5500615063885302245_n.jpg
    the hood I'm getting is the one pictured in the catalog
    I even THOUGHT About a Westcoast Dual Spark system.... but I opted not to, cuz its ridiculously rare and probably pretty expensive IF I can find one. plus my knowledge is limited with it i'll post pictures of the boat in its current state later.
    90' 550SX "Shaved head, .5mm+ Wiseco pistons, SBN 44, Kerker exhaust, Mariner waterbox, WestCoast OS Gas Tank, extended ride plate,(440 pump) 16deg SS Skat imp."
    WIP - 83' JS550 " .5mm+ Wiseco pistons, WestCoast: Head, rc520 reed cyl, 7 Ring Exhaust, Ext Ride plate, Ex Manifold, 2x Velocity stack, waterbox, Westcoast Dual 38 intake, Dual SBN 38s, 440 pump and a 16.5 degree SS Skat imp. Lightend flywheel"
    97' Tigershark Monte Carlo 1000 fresh top end and runs finally!
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    Re: Westcoast Themed 550
    Subscribed
    Got any more pages to the catalog?
    Sent from my XT1650 using Tapatalk
    - 03 Superjet - 1mm over bore, hooker 9/15, destroyer tubbies, carbon ride plate, cold fusion turn plate, quick steer mod, UMI bars, blowsion pole spring, jetmaniac girdled head, limited chamber b pipe
    - 94 WB1 - protec ride plate and top loader, 61x61x (FOR SALE)
    - 92 550sx - under construction
    - SNSJ - dual 44sbn, protec girdled head, 735cc, 62t61x, cylinder ported by tim tynan, protec exhaust, bored nozzle, 10/16, worx 201 top loader
    Top Dog
    Sep 2008
    @ afraz1er Nope that was a lucky find, the guy who had hood mold showed me that page to confirm that was the hood I wanted.
    As promised here is pictures of the boat getting the make over, i'm gonna start the tear down in a week or 2 when i get a break from the rain.
    here is the first bit of work Done, these are stock 750 reeds, thing is 750s have 12 studs for the reeds as where the RC520 Cylinder only has 11 studs. so to make the reeds fit the Inside stud holes on reeds needed to be ground down.
    Next step I have to Send out Flywheel motor and pistons out to be machined @ newmillers
    SE MI
    Hood mold, is he available to make more?
    Top Dog
    Sep 2008
    I can Ask.
    Top Dog
    Sep 2008
    Parts being Sent out to Newmiller.
    Sep 2005
    AZ
    Nice intake mani - those are rare!
    Reed cages - Westcoast just cut a little off the end of each one and used the OEM stock cages.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust.
    PWCToday Regular Kansan's Avatar
    Shawnee Kansas
    Following this cool build.
    '79 JS440(550 swap)
    SE MI
    Quote Originally Posted by stixx925 View Post
    Do you (or anybody) have any literature on these?
    Top Dog
    Sep 2008
    @BLRider I dont its a guessing game for me, been trying to contact of Terry Beatty or Herry Klemm.
    @MrSki Thanks for the Mani!
    I haven't mad any progress this week, my right hand man to help with tear down had to work, plus busy with real estate agent and lender. aside from that Chris at Newmiller recived my parts to be machined.
    Picked up a Windrosa Head and exhaust gasket plus a new set of Pro-X crank seals and lastly a Bilge pump (hope its right one).
    Anyways the next steps are i'm going to remove everything from inside the hull, pressure wash it, then use an off-white glossy appliance paint and do the inside of the hull.
    Also I think I'm going to paint the mounts red. I just don't know what I'll paint the Bedplate or the crank cases (gonna pressure wash these too)... opinions welcome.
