    Frequent Poster superstock1986's Avatar
    Mar 2006
    Bay City Michigan
    WTB hydro 1100 conversion kit
    HI,
    I need the 1100 hydro conversion kit. Does anyone have any for sale?
    Thanks
    PWCToday Guru kotarbi's Avatar
    Jan 2003
    san antonio tx
    Re: WTB hydro 1100 conversion kit
    Not sure about a kit but here is some info. Got my bedplate on here. Search conversion in this forum and you'll find the thread. Not sure if he's still making these. Or try dales jetsports. I used one Ada S4 coupler and one Ada 12f coupler i believe. They are the same dimensions but different thread. I had the end of my pipe cut off and welded on a 90deg cast elbow. Bought some exhaust pieces from eBay to make the connection. The pipe is going to hit the side of the hull. Youll have to cut the hull or mod the pipe or manifold. I cut my hull
    I didn't want to cut my bulkhead so it's a tight fit. Custom eBox in front of engine. I also have 25lbs of weight center / right in hull to balance it back out. It road like crap before that It's a fun ski now. No more lag
    07 Hydro Triple!!
    06, 07 SXR's
    93sx-Pro
    85,87 wetbikes
    Jan 2003
    san antonio tx
    I was asked about this. Here's a few pics
    07 Hydro Triple!!
    06, 07 SXR's
    93sx-Pro
    85,87 wetbikes
    PWCToday.com Is My Home Away From Home sxr951's Avatar
    Aug 2007
    Mecong Delta, Florida
    amazing!
    Aug 2007
    amazing! top speed?
    PWCToday Guru veedubs's Avatar
    Jul 2012
    Atlanta Georgia
    Where did you get this engine plate?
