Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
  1. #31
    Chicago / Portage, MI
    Re: 650 sx triple 900 adaptation
    Video looks good and the ski roars/ snarls like it should. Great job man. Post up some GPS speed info if you can.
    2009 1100 SJ:
    Kawi 1100 build in progress
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
  2. #32
    PWCToday Newbie barlosbhz's Avatar
    Aug 2015
    brazil
    2
    Hello TheVetteman3. I have not had a chance to measure speed yet. I believe that in about twenty days I go back to walk on it, hence I will record more videos and measure. It is with original propeller KAWA SOLE X PROPS 16/23 - KF-SC-X. I accelerated along with a seadoo xp 800, I left behind.
  3. #33
    Aug 2015
    brazil
    2
    Guys, I have a kawasaki zxi 900 motor, and I'm thinking of turning it into 1100, since it needs rectifying. buying cylinder, connecting rods, pistoes and doing work in the chambers, is this transformation possible? Are the 900 and 100 motor housings the same?
  4. #34
    Aug 2015
    brazil
    2
    Hello theVetteman3, I need an opinion about compression of the zxi 900 year 1995 engine. I decided to make my engine, I bought an original kawasaki 900 cylinder in the grease, and I bought pro-x pistols with Teikoku rings. I mounted the engine, when running the compression test gave 75 PSI, I found it very low, is it normal being factory standard pistons and cylinder? engine has not yet spun in the water.compress 900zxi carlos.jpegcompress 900zxi carlos.jpegpro x carlos.jpeganesis carlos.jpeg
  5. #35
    Aug 2015
    brazil
    2
    Can anyone help me, why did the compression get low, everything new, seals, gaskets,?comp 02.jpegcomp 03.jpeg
  6. #36
    SE MI
    Your cylinders are even at least, did you measure your ring gap before assembly?
  7. #37
    May 2011
    miami
    Have you used that gauge on other engines with proper compression? Some gauges can be off by as much as 60psi.
  8. #38
    Aug 2015
    brazil
    2
    Rider, cylinder, cylinder was purchased original kawasaki has never been used and this standard. There was no slack since everything was bought new, complete cranks, bearings, pistoes. I did not say no, because it was an original factory cylinder, I trusted it.
  9. #39
    Aug 2015
    brazil
    2
    I used this same gauge on this engine before disassembling it, and incredible 80 psi seems incredible. Now with everything new the compression got lower. I have not walked the engine yet, is there a possibility of compression increase by ring-laying?
  10. #40
    I believe a good or normal operating range for these engines is 120 psi +/- 10 psi.
    The original engine was 80 psi? Have you used this cylinder head before? Are you using any base gaskets?
    Such a large difference I have personally only seen from wrong domes/ head (ccs too large), using gaskets which are too thick, or a bad gauge. I would test with another gauge if possible just to rule that out.
    2009 1100 SJ:
    2009 SJ MINT:
    1987 WJ650:
    1998 SXI PRO:
    3DR hull mods [TBD]
