Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jun 2013
    US
    X4 155 pump conversion
    Ok, where's all the threads for the 155 pump conversion on a x4 hull. Time to get started on this 1100 project!
    Can I just grind out the stock pump shoe until it fits or do I have to make a 155 pump shoe fit? Which way is easier? Any tips?
    PWCToday.com Is My Home Away From Home justforfun's Avatar
    Nov 2006
    Lehigh Acres, Florida
    Re: X4 155 pump conversion
    When I did my 951 conversion on the XP I just ground the shoe and elongated the holes in the pump to work, worked great with no issues.
    Dec 2011
    Niceville, FL
    Jun 2013
    US
    Thanks Matt! Did you open up the tunnel at all so the water flows better?
    Dec 2011
    Niceville, FL
    They did I think. This was done by some central Florida friends of mine.
    Quote Originally Posted by Thomps33 View Post
    Or you could just grab a Skat 148mm and be done with it.
    Jun 2013
    US
    Quote Originally Posted by Alter Ego Trip View Post
    True, but the skat costs 5 times more and I think the 155 will perform better.
    It might. When speaking in depth about it with Wayniac; he gave the nod to the Skat over the 155 swap. I personally think it's splitting hairs at the end of the day for 99% of us and the 155 is a whole lot cheaper.
    Justin would be a good one to talk with as I believe he has ran both. Either way there is a huge advantage to be had over the stock setup.
    Top Dog jdakrt's Avatar
    Mar 2006
    Chesterfield VA
    Both have adv/disadv. The 148 is a bolt in swap, but we had issues with the pump seal getting sucked in due to the 1100 torque. Didnt matter foam or rubber, both were good for about two rides. Also, note your still feeding the 148 with a 140mm pump shoe, so there is only so much volume to process water. That said, the 155 is a must have if your planning on building anything over a mild/stock 1100. This lends a whole other sealing issue, as your modifying the shoe and thinning out your sealing surface to accomodate the larger diameter. You MUST make the shoe match the face of the wear ring/pump, and use right stuff or permatex (sp) to ensure a good seal. I enlarged my shoe by hand with a die grinder and aluminum bit. Scottie sent his to the machine shop. Either way works. I did open up the intake tract 3mm or so, all the way forward, but you will need to lay up the tunnel reinforcement before opening it up. One needs to do this anyway as your cutting into the lip of the tunnel for the 155 pump. Take pics as you go and we can guide you thru it.
    "PITD" proud member of
    Team TFP
    I've been pretty lucky; I've had zero issues with the 148 seal. I ran the foam seal along with black RTV and no issues. Would the 148 to 140 not provide for more thrust on the same principle of holding you finger over a garden hose? Just thinking aloud.
    Quote Originally Posted by jdakrt View Post
