    Jan 2017
    Norway
    Where buy piston and gaskets
    Hi
    I'll overhaul the engine in my FX1. Where is the best place to buy new piston and gaskets? Some brands that are not good that I should stay away from?
    PWCToday Guru Jim_ii's Avatar
    Aug 2011
    Michigan
    Re: Where buy piston and gaskets
    I've had good luck with WSM top end kits. Prepackaged with everything you need (pistons, rings, wrist pin, bearings, circles and a gasket set). Good luck!
    Mar 2011
    Brooklyn Center, MN
    When i buy pistons for my jetskis i buy ProX or WSM
    Gaskets im not that picky on besides the head gasket should be OEM (ive blown out the cheap head gaskets before on kawasakis)
    I have kits in stock, pistons, rings, pins, clips, top end bearings, gaskets, crank seals, and more.
    We ship oversea's daily.
    Best to email watcon@watcon.com
    Please visit our web sites
    Aug 2010
    Australia
    SBT will have all the parts you need ! , and shipping costs wont bust your balls !
    modded X2 650
    Originally Posted by hyosung
