Results 11 to 20 of 41
    PWCToday Regular corwin06's Avatar
    Jun 2014
    minnesota
    Re: Just bought an FX-1
    And also a factory B head pipe came with it forgot to get a picture of that
    Js 550- west coast pipe, k&n intake, bigger carb, quick steer
    May 2007
    You have a stock tray not wide. The pipe does have a fx1dent but not sure its a true fx1 pipe, could be a limited, still great pipe. You still got a very good deal eaither way. Post some engine pics and let us see
    What engine you have.
    Jun 2014
    minnesota
    The pic is from the ad looks really really clean in there 147 psi both holes
    Jun 2014
    minnesota
    I believe that is a 701, correct?
    May 2007
    If its the engine that came in the ski then yes. 6m6 650 look the same. Should be tag on intake and stamp on head and cylinder 61x
    May 2007
    And yes pertty clean ski for cali.
    Jun 2014
    minnesota
    Thanks. I'll have to check the numbers to confirm it is in fact a 701 I just assumed it was since that's what they came with and the owner didn't say otherwise. its missing the side turf for some reason too just thinking of buying a sheet and cutting it myself to replace it and adding some to the side rails too while I'm at it and also tuning the carb for the new exhaust system
    May 2007
    Sbn 145 high jet and 120 low jet. Get a new 1.5 n/s. Looks like you have am fa do 35 to 40 pop off
    is what ur looking for. Turn and 1/2 low screw, 1 turn on high to start with. Wouldnt hurt to install new car kit too.
    Jun 2014
    minnesota
    Well that's saves me a lot of trouble thank you might be a little bit until I get around to it though, not much water up here right now though lol
    Jun 2014
    minnesota
    This is the factory B head pipe I mentioned, also came with a k&n air filter flame arrestor IMG_4487.JPG
