I am in the process of rebuilding my pump on my 01 rx di. One question I have is when I press in the oil shaft seal, what side faces outward? It seems kinda tight. The last seal I pressed in, I put it in so that the open end/the spring, was towards the bearing. When I put the shaft in, it folded over the seal and popped the spring out and messed it all up. Do I need to flip it around so the spring faces upward?
Shaft seal ?
Collapse
X
Re: Shaft seal ?
If you're talking about the front seal of your jet pump the spring goes inside, hard flat surface facing the impeller. Grease the shaft and seal when you slide it forward then go slowly and rotate while you push.http://www.facebook.com/twinlakesjetskirepair
Comment
Re: Shaft seal ?
The video is wrong....the spring on the seal goes outside.
I have installed many seals with the spring inside with no issues. You would think the seal goes inside to keep from deterioating but have since rebuild quite a few OEM jetpumps (never worked on) & the spring was on the outside.sigpic
Comment
Re: Shaft seal ?
Starts talking about the seal orentation on page 3 ...........http://www.pwctoday.com/showthread.p...ump+shaft+sealLast edited by Grumpy Old Guy; 01-02-2017, 01:08 PM.sigpic
Comment
Re: Shaft seal ?
NICE! Well I guess it really doesn't matter then. I've literally installed probably 100 of them with the spring to the inside. But I also use a double lip seal.http://www.facebook.com/twinlakesjetskirepair
Comment
Re: Shaft seal ?
Seal 101 ----the spring side of a seal goes to the side with the most pressure. It may work either way in some cases but in applications where there can be a large differential pressure (pump/engine/transmission/ gearbox seal) going to atmosphere the seal needs to go with spring inward.The thought that leads to no action is not thought - It is dreaming!!
Think Big!!
Comment
Re: Shaft seal ?
Seal must be installed so that lips raised edges are toward outside of housing (toward impeller).- How many gerbils could a gerbil jammer jam if a gerbil jammer could jam gerbils?
Comment
Re: Shaft seal ?
Seal spring should face the impeller (out).
Chester
2005 SeaDoo Vehicle 2-Stroke Shop Manual.pdfSpeed is very expensive. How fast do you want to spend?
Stand up:
98 SXi-Pro
Couches:
96 XP
86 X2
Comment
Comment
