x2 750 wan't more low end - Page 2
Results 11 to 20 of 30
    PWCToday.com Is My Home Away From Home cameron da river rat's Avatar
    Jul 2003
    In the Garage.....
    Re: x2 750 wan't more low end
    westcoast is a top notch head, i run that head in a couple of my skis but not sure what the 27cc domes will pump out? good thing is they are interchangeable domes.....ive sold a lot of westcoast and ocean pro heads i wish i still had. besides the pipe, prob the best bang for the buck.
    your English is fine....lol....or our slang version of it.
    aka "Cameron Da River Rat"
    (jetskianist~addicionist~modificationist)
    www.jetski247.webs.com
    92 550sx 650 conversion sweet.........
    94 fx1 (under modification)
    2 X2's (under modification) one for the kiddo
    98 spx stock/fpp spec2 (broke)
    03 genesis i (huge pos)
    95 f150 tonka toy
    04 suby sti
    PWCToday Guru Udjenl's Avatar
    Aug 2013
    The netherlands
    haha thanx, what headgasket do you use on a westcoast with 750 domes?
    work hard and play hard
    or let someone else work hard and still play hard.
    but enjoy life every freak'n day
    Top Dog bandit88's Avatar
    Green Bay WI
    Quote Originally Posted by Udjenl View Post
    http://www.pwctoday.com/showthread.php?t=464305
    -95 750SXI
    -90 TS650
    -91 300SX
    Aug 2013
    The netherlands
    gonna be an expensive one... to the netherlands...
    i read some people use a oem gasket.. is that possible?
    Green Bay WI
    Nope, bore on a stock one is too small. The correct gasket is like 23 USD, shipping something that small and light wont be much. I shipped a muffler to Germany for $50, the gasket will probably like $25.
    -95 750SXI
    -90 TS650
    -91 300SX
    I dream skis tjindo16's Avatar
    May 2009
    Citrus County, Fl
    I have a 750 small pin in my x2 with Sxr carbs and a hooker 9/15 and it has a **** load of pull. Also few other mods
    Aug 2013
    The netherlands
    after a burn-out and still recovering.. i am back. have tryed the 9/15 skat and run crap...
    setup at the moment,
    750sp
    46mm carb. single
    factory wet pipe
    advance timing plate
    coffman waterbox
    wetwolf pumpcone.
    i have the idea it won,t get fast on his rpm,s
    could advance timing plate cause this?
    Top Dog hooka-2's Avatar
    Nov 2005
    sebring florida
    sxr prop repitched to 10-18 hits hard with a well build sp 750. You need to be running 180 psi compression and an extra little boost can be had by lightening the flywheel. I think "Zero" o X-h20 is still doing them for 65 bucks
    90 X2 (750), 92 X2 (750), 93 X2 (750),93 X2 (750), 99 Ultra 150(sold) 1995 Waveblaster 1
    Aug 2013
    The netherlands
    thanx for the info,
    next week i gonna buy a high compression head and a lightned flywheel and gonna put the 13/18 on it to test with that setup.
    Nov 2005
    sebring florida
    thanx for the info,
    You're going to find that the 13/18 is a little bit lazy on the bottom
