Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    PWCToday Guru Udjenl's Avatar
    Aug 2013
    The netherlands
    x2 750 wan't more low end
    hello,
    i am wan,t more low end so i can do a little more freestyling
    need some tips..
    i already going to do the next mods:
    750 SP
    FP exhaust (any tips for low end tuning?)
    single 46mm
    advance timing plate
    wetwolf pumpcone
    maybe a high compression head to bump around 180psi
    dual cooling
    sxr cutback impeller oke?
    work hard and play hard
    or let someone else work hard and still play hard.
    but enjoy life every freak'n day
    PWCToday.com Is My Home Away From Home Rod Peters's Avatar
    Jul 2010
    No. Colorado
    Re: x2 750 wan't more low end
    hooker 9-15 or lower by impros
    Frequent Poster got dirt?'s Avatar
    Dec 2008
    Savannah Ga.
    Quote Originally Posted by Rod Peters View Post
    With a pump stuffer
    BRAAP!
    Aug 2013
    The netherlands
    a 13/18 sxr impeller is to big?
    9/15 is hard to find here.
    i allready have some impellers laying around
    like a 15 does this come close to a 9/15?
    is there a list to check impeller pitches ?
    Jun 2013
    Atlanta, Ga
    If you don't have the 750 yet many of them came with factory dual Keihins. If the motor you get has theses carbs don't change them out, use them. The build thread in my signature shows how I modded the right hull brace to use the dual Keihins and K&N filters. I messed around with the jetting but ended up back with the factory setting. The thread also shows how to easily add knobs to the carb needles and do a full 2" exhaust system with the Blaster pipe.
    If you are experienced with a Dremel tool you can port-match the block. Basically you gently grind away at the aluminum that does not line up with the port windows of the cylinder sleeves. You do NOT change the windows themselves. If the engine has a lot of hours on it send the block to a machine shop for honing and put new rings on the pistons.
    Personally, I prefer a 1/2 cooling mod to dual cooling. The reason for this is that the fitting boss on the pump is large enough to accommodate a larger 1/2 fitting. If you opt for a second fitting you will be drilling and tapping it in very thin metal. Guys do it all the time, but the 1/2 inch fitting is the better way to do it. If you don't want to mod the through hull line you could put a T fitting back in the pump cavity and use the 1/2" fitting to feed the two smaller existing lines.
    Bob
    Aug 2013
    The netherlands
    already have it all in my x2,
    dual cooling is allready in.
    SP and 46mm single
    i have the old type FP head 42mm
    and using the SJ LTD pipe.
    porting i will do on my next rebuild.
    most important question what impeller is a sxr impeller good to start with?
    and i have a westcoast head with 27cc domes laying around... could this be a save install to get around 180psi?
    (the gray 750SP came with single 38. )
    Resident Guru still standin's Avatar
    Jul 2009
    michigan, KZOO
    The SXR impeller is a 13/18 and they are a bit heavy.
    A hooker 9/15 would be great or a Skat trak 9/17 C75- Swirl.
    -Bulldog Freestyle 550/750 - http://www.pwctoday.com/showthread.php?t=457962
    -92 550sx/650 conversion
    -94 750sx modded
    -86 X2 - Twin carb 750 swap
    Aug 2013
    The netherlands
    oke thanx
    and the head?
    PWCToday.com Is My Home Away From Home cameron da river rat's Avatar
    Jul 2003
    In the Garage.....
    Quote Originally Posted by Udjenl View Post
    oke thanx
    and the head?
    you can buy an aftermarket head that will raise compression....raised compression will give you good bottom end punch as well as mid range......if you mill a stock head, you will need to watch your squish depending on how much you mill but if you get near 180 with all your mods and don't run good fuel 93oct or better then you might deto to death. since your advancing the timing as well as a pipe already.
    if you mill, take a piece of solder, stick it in the spark plug hole at an angle to hit the cylinder, spin the engine over to squish the solder and measure it and see if its within spec, if not then having that angle milled inside the head could cost as much as a good used aftermarket head but i know finding a good aftermarket 750 head is not easy.
    aka "Cameron Da River Rat"
    (jetskianist~addicionist~modificationist)
    www.jetski247.webs.com
    92 550sx 650 conversion sweet.........
    94 fx1 (under modification)
    2 X2's (under modification) one for the kiddo
    98 spx stock/fpp spec2 (broke)
    03 genesis i (huge pos)
    95 f150 tonka toy
    04 suby sti
    Aug 2013
    The netherlands
    i have westcoast head with 27cc domes laying around. any good?
