Results 1 to 10 of 16
    PWCToday Newbie simonb's Avatar
    Jul 2012
    UK
    Kawasaki 1100 v 900 pipe
    Is the Kawasaki 900 pipe exactly the same as the 1100 ? Is their any performance differences. I have an 1100 manifold and main body but only have a 900 top section and don't want to use it if it is down on power.
    PWCToday Regular macaddict001's Avatar
    Nov 2012
    jacksonville, fl
    Re: Kawasaki 1100 v 900 pipe
    I believe the diameters are different, but don't have them to measure. The 900 pipe would restrict flow unless modified. On my ZXi1100 mutant, I actually grabbed a DI manifold + pipe sections (larger volume) and DI exhaust muffler, and did stage 1/2 mods to the manifold runners (opened those runners up 2mm and elbow 3mm) and a 1" hole in back baffle of exhaust muffler..... huge difference in grunt, especially when coupled with Jetworks flow control stinger mod....
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    2001 Kawasaki ZXi 1100cc
    CDKII Triple Carb | R&D Power Plenum | +1.5 Wossners | HotRods Crank | R&D Intake | Shredmaster Ride Plate
    Solas Concord 13/19 | Dual Cooling | Jetworks FCV Stinger Mod | Temp Sensor Mod | Waterbox Mod | DIY 2" Nozzle Extension
    2001 Seadoo XP 951CC
    PROK F/A's Rejetted | +1.5 Wossners | 97.5 Unicorn Pipe | Solas Concord 15/20 | Solas Intake Grate | PJs Finger Throttle
    Silver/Tangerine Candy Apple/Yellow Paint | Carbon Fiber Vinyl Seat | TrimFix | Rhaas Urethane Mounts
    May 2002
    Blasterville, USA
    Totally different. 900 pipe is shorter, smaller inlet and outlet and much less volume. The headpipe is much smaller as well. There were some modded 900 chambers floating around a while back, but they didn't work well, no bottom and very pipey in the mid.
    SM
    Proud Member of TEAM TFP!
    JAM Racing
    Judge Motorsports
    www.hotproductsusa.com
    www.optimaracing.com
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ProWatercraftracing.com
    www.ipdjetskigraphics.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    Jul 2012
    UK
    Many thanks.......will keep looking for an 1100 head pipe as I have the rest.
    We have found the same in our testing here. Stick with an 1100 pipe, and dry it out.
    email watcon@watcon.com
    Please visit our web sites
    May 2002
    Blasterville, USA
    Simon,
    Ebay is the best place to find them. Also, I always look for parts in the middle of the US, that way it is very unlikely they have been used in salt water.
    Good luck in the search,
    Scottie
    JAM Racing
    Judge Motorsports
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    Aug 2010
    Australia
    hi tech rocket science! testing the difference in power between the 900 and 1100 chamber , i wonder if the techs at watevercons hooked up the bench flow place divert-er combined with the ram air micrometer to do the testing ,
    modded X2 650
    Originally Posted by hyosung
    Quote Originally Posted by hyosung View Post
    Why are you always trying to ram something where it doesn't go ?
    Top Dog
    Oct 2006
    under a ton of work
    why don't you lay off of it for a while.i fully support the 1st amendment but sometimes your comments have no common thread with the topic at hand.
    i understand you have gripes with some members here but geez! let it go once in a while.
    Quote Originally Posted by restosud View Post
    That part I don't get is why he chooses members like MCN6 and Zig to bag on, if it was someone like the Rad Dudes I could probably understand.
