Kawasaki 650 TS
Thread: Kawasaki 650 TS
    Jul 2010
    NJ
    Kawasaki 650 TS
    1990 Kawasaki TS. When I went to start up the ski today it cranked a few turn and then locked up. There was a gurgling sound when it happened. I pulled the plugs and cranked it and I got an oil bath. The oil tank was full. But after trying to crank it a few times it is now empty. What happened?
    Green Bay WI
    Re: Kawasaki 650 TS
    Bad check valve and oil filled the bottom end? Just a guess
    Jul 2010
    NJ
    Re: Kawasaki 650 TS
    Is there a check valve in the oil injection plate?
    PWCToday Guru Rideallseasons's Avatar
    Aug 2013
    Up State NY
    Re: Kawasaki 650 TS
    I purchased an x2 that did the same. Pulled the plugs and did a few squirts of oil to the cylinders before cycling to prep for a compression test after sitting so long and found out a split second after the whole motor had the oil tank in it... Ski was stores up right supposubly but never understood how that happened.
    Nov 2016
    Santa Monica
    Re: Kawasaki 650 TS
    Quote Originally Posted by Rideallseasons View Post
    Same here.
    I think all you need is Leanbean to feel better.
