2010 Hydrospace and spares
Results 1 to 10 of 11
    Nov 2016
    Australia
    IMG_0432.JPGIMG_0414.JPGIMG_0415.JPGIMG_0416.JPGIMG_0417.JPGIMG_0418.JPGIMG_0419.JPGIMG_0420.JPGIMG_0421.JPGIMG_0422.JPGIMG_0423.JPGIMG_0424.JPGIMG_0425.JPGIMG_0426.JPGIMG_0427.JPGIMG_0428.JPGIMG_0430.JPGIMG_0431.JPGIMG_0433.JPG
    2010 Hydrospace fresh engine (2 hrs since rebuild), heavy duty studs , valve springs , Carrillo rods and pistons, Motec M130 ECU, high volume injectors,Wave racing intercoolerTBM ride plate scoop grate.
    List of spares etc as follows-
    • all exhaust hoses
    • Complete turbo and manifold
    • Waste gate
    • Carrillo rods and pistons
    • New complete wiring loom
    • New starter
    • New fuel pump
    • 2 x new black ecus
    • New Oil tank
    • Oil catch tank
    • 4 x standard injectors
    • 4 x standard air filters
    • 14/17 Skat
    • 21/22 Skat
    • Oil cooler and all associated hoses
    • New standard intercooler
    • 3 x standard intercooler brackets
    • Standard stud set
    • Standard pump ring
    • Standard steering nozzle ring
    • Standard aluminium ride plate
    • Standard carbon ride plate
    • Comprehensive set of Big end bearings/main bearings and valve shims
    • all factory engine rebuild equipment
    • oil filters spark plugs various sensors
    • Comprehensive set of Oertiklor clamps
    • Factory service manual and owners manual
    • New Jetrim mats and pole pad
    Ski is located in Australia and will be sold with Air freight compliant aluminium shipping case
    $9500 AUD
    Nov 2016
    Australia
    Re: 2010 Hydrospace and spares
    $9000
    Nov 2016
    Australia
    $8,5000 AUD
    Ski was used to win an Australian Title and countless other races throughout Australia.
    Heres a bit more of a list including rough pricing of spares that are to come with the ski-
    SPARE PARTS
    -Assortment of Bosch map sensors both new and used but still working ($100us each)
    -Brand new mid shaft bearings($40)
    -Oil filter ($20us)
    -4 standard flame arrestors($110us each)
    -Assortment of specialty weber tools($400us)
    -Brand new fuel pump($140US)
    -Used fuel pump but still in working order($140us)
    -Spare Motec data cable-
    -Almost new oil tank($140us)
    -3 stock intercooler brackets($90us each)
    -Standard intercooler($800us)
    -Brand new throttle cable($65us)
    -Standard Couplers ($200us)
    -Spare pump and reduction nozzle rings($150us)
    -oil overflow tank ($90us)
    -oil coil and thermostat including all hoses($400us)
    -standard carbon ride plate($200us)
    -standard aluminium rideplate($200US)
    -Wastegate actuator($80us)
    -workshop manual($50us)
    -complete wiring harness($500us)
    -standard hsr data cable and software($230us)
    -used standard crank but still in reasonable condition ($800us)
    -complete turbo and exhaust manifold assembly($2500us)
    -2 standard ECUs ($500 each)
    -Fuel rail and assortment of injectors($250us)
    -standard intercooler hoses($50us each)
    -Near new standard con rods ($200)
    -near new carillo con rods and pistons complete($1500us)
    -brand new head gasket($100us)
    -2 sets crankcase studs ($190us each)
    -fuel pressure regulator ($150us)
    -Weber engine rod and main bearing kit ($328us)
    -2 assorted pitched props($300 each)
    Nov 2016
    Australia
    $7,500aud
    Nov 2016
    The Pond
    Any idea on shipping to the US?
    Nov 2016
    Australia
    Does not come with aluminium shipping crate anymore
    Nov 2016
    Australia
    $7000
    Nov 2016
    Australia
    $6500
    out of curiosity as a fellow Aussie which state?
    Nov 2016
    Australia
    Sorry spenaroo I did not see your post. It's located in Victoria.
    Price is now $6000aud
