Results 1 to 10 of 18
    Top Dog
    Dec 2007
    WI
    b1 kaw1100 any one done a reasonable sounding one
    mine are too frickin loud
    Sep 2008
    City of Blasters
    Re: b1 kaw1100 any one done a reasonable sounding one
    What do you have for waterbox?
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Traci Cottle Photography
    Greg Barnhart Photography
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    Top Dog
    Dec 2007
    WI
    gp 760 box with 10 1/2 holes drilled in plate, then welded up 5 holes on my other b1 1100 and it made no diff. and rear exit,not in pump area.
    Sep 2008
    City of Blasters
    I have the same but 8 holes. I don't think it's that loud.
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
    May 2002
    Blasterville, USA
    Putting a downturn on the outlet of the hull helps. It's still throaty, but it's better than straight. (Think of how a stock sxr outlet looks)
    The other thing you can do is to add a water line to the outlet. Honestly, I don't notice much with this. I'm surprised no one has done two boxes like the yamaha 1100s, just don't know how this would effect performance.
    SM
    Proud Member of TEAM TFP!
    JAM Racing
    Judge Motorsports
    www.hotproductsusa.com
    www.optimaracing.com
    www.nynjapwc.com
    Judge Motorsports
    www.raddudesfi.com
    ProWatercraftracing.com
    www.ipdjetskigraphics.com
    ADA Racing
    Monster Motorsports
    A&R Performance
    Top Dog jdakrt's Avatar
    Mar 2006
    Chesterfield VA
    Also noting the ZXI inlet perforated tube has helped quite a bit. not bad to get out, and should fit in the 760 box. It's basically a resonator, designed by kawi for the 1100 motor...
    "PITD" proud member of
    Team TFP
    Top Dog
    Dec 2007
    WI
    so cut up the stock 1100 zxi box
    Mar 2006
    Chesterfield VA
    Yes, alterego x4 build had a pretty good description on how to do it. Basically drill out all the spot welds on the zxi box, cut around the inlet side weld (outer diameter), and cut it lengthwise (just the shell) twice in two locations 180 degrees apart. the baffle assy witt then fall out once you split the clamshell you have just made. Then knock off the baffles that are spot welded to the resonator assy. Trim the OD of the inlet cap of the zxi box to match the OD of the raider box. should fit even with the raider baffle in tact. take pics along the way to show everyone.
    Team TFP
    Top Dog
    Dec 2007
    WI
    i suck at searching! how do i find his build? thanks
    Sep 2008
    City of Blasters
    Thanks to
    Optima Racing
    C57 Racing Products
    NorCal Watersports
    Newmiller Machines
    Boyko Racing
    Fly Racing
    Jettribe
    Impros
    Jettrim
    Rhaas Products
    Rad Dudes
    DJSA Racing
    Serano Tile/Stone
