61x Parts, 650 Engine, Wetjet Pipe
    PWCToday Newbie LazerBear's Avatar
    Tracy
    Extra parts for sale from a build im not going through with
    paypal only, no international shipping
    61X cases empty, in excellent shape, one raised spot near a bolt hole that will need to be shaved - $65 shipped
    61X cases with Crank and rods, has Kawi driveshaft adaptor and electronics. Was a running engine, crank and rods in good shape, cases are a little ugly and the bolt holes for the starter are messed up. - $225 shipped
    61x Cylinder, again off of a running engine, needs a hone, has some studs from a pro tec pipe, po put some epoxy on them to hold nuts on so will need a cleaning. - $85 shipped
    almost brand new 44mm sbn carb - $100 shipped
    Blowsion orange flame arrestor and 46mm (will fit 44mm) adaptor - $55 shipped
    Yamaha oem couch motor mounts in great shape $ 45 shipped
    yamaha oem mount set 3 couch mounts and one stand up mount (need a cleaning) - $35 shipped
    rn superjet fire extinguisher holder ( faded on top) - $25 shipped
    brand new oem 61x flywheel cover - $15 shipped
    Pro tec modded ignition (ugly but works) - $45 shipped
    Brand new am bendix - $25 shipped
    oem driveshaft cushion - $15 shipped
    rad dudes diaphragm mount for throttle cable - $15 shipped
    Werjet pipe, needs a cleaning, all hardware and mounts included - $60 shipped
    650 engine, super clean, low hours out of a vxr runs great. local pickup only in tracy california - $400
    oem yamaha ebox, has had some water ingress, everything works, no ignition no seal, has some holes drilled in the ears - $35 shipped
    IMG_2321.JPGIMG_2340.JPGIMG_2339.JPGIMG_2335.JPGIMG_2329.JPGIMG_2328.JPGIMG_2327.JPGIMG_2325.JPGIMG_2323.JPGIMG_2319.JPGIMG_2320.JPGIMG_2345.JPG
    Brigantine New Jersey
    Re: 61x Parts, 650 Engine, Wetjet Pipe
    Can you get those studs out of the 61x cylinder case?
    Tracy
    Quote Originally Posted by dheaney18 View Post
    yes they come out
    bump
    also 44sbn sold
    Aug 2018
    Springfield, MO
    Any chance you still have the manifold and exhaust/engine bracket and would like to sell?
