93 SL750 parts cheap!!
Parting out a 93' SL750. Started life in Hawaii, I am the second owner. Pistons wore and I have three other skis, no desire to rebuild.
I am selling everything off of this ski, hull included if you are interested in it.
Jet Pump - $50 + shipping trim model, needs some work, bearings are worn and impeller appears worn.
Handle Bars - $5 + shipping
Full stock exhaust - $10 + shipping
Starter - $15 + shipping
Driveshaft - $5 + shipping
Cylinders - $10 + shipping
Reed cages with stuffers - $30 + shipping, great condition
Fuel level sending unit - $10 + shipping, worked great
OEM ride plate - $0 + shipping
Ebox - $40 + shipping, worked great, interior extremely clean
Short block - $50 + shipping, stator, crank, rods, mount plate, case halves, oil injection pump, and stator cover
Intake Manifolds - $5 + shipping
Carburetors with triple outlet fuel pump - $50 + shipping
Fuel inlet retainer - $10 + shipping, this is the upgraded aluminum variant
Fuel tank - $0 + shipping
If you want anything not listed, just ask and I'll give you a price; pump shoe, hoses, random bolts, plastic pieces if I have them in good condition, and things like the seat and hood will go for price of shipping.IMG_20160902_190652693_HDR.jpgIMG_20160927_200838826.jpgIMG_20160927_200846679.jpgIMG_20160927_200858700.jpgIMG_20160927_200910112.jpgIMG_20160927_201037950.jpgIMG_20160927_200807034.jpgIMG_20160927_201350437.jpgIMG_20160927_201358501.jpgIMG_20160927_201423418.jpgIMG_20160927_201438875.jpgIMG_20160927_201722154.jpgIMG_20160927_201740375.jpgIMG_20160927_201750823.jpgIMG_20160927_201811417.jpgIMG_20160927_201952214.jpgIMG_20160927_202010262.jpgIMG_20160927_202637103.jpgIMG_20160927_202706450.jpgIMG_20160927_202712276.jpg
Re: 93 SL750 parts cheap!!
The trim motor did work and is for sale too! Along with the trim gauge, fuel gauge, and pet****
Moderator
Moderator
Hi, still have the Gas tank and the fuel level sending unit ? Carbs with fule pump ?
I need them
Thanks,
T
2008 Sea Doo Speedster
2002 Sea Doo 4Tec Limited
2009 Ulra LX ( Sold )
2014 Ultra LX ( Sold )
2007 Ultra250x ( Sold )
2002 STX-12F ( Sold )
Hello, I do still have the Carburetors with fuel pump and the fuel level sending unit. I will have to check for the fuel tank, I've started throwing bigger plastic items away as no interest has been shown.
Is that crank good to run? Turn smooth?
The crank should be good, still turns smooth as silk. I already have the flywheel pulled off from someone who said they wanted it and never followed up. Crank is in the case, but I can disassemble for more pictures if you are interested. Thank you.
How much for the crank with cases shipped to 72635?
Moderator
Moderator
Carguy,
Can you PM me again ?
I'm traveling out of the US and am not sure if you got my PMs.
Thanks,
Todd
I just sent you another one, let me know if you got it. I'm still trying to get these alerts into my inbox so I can see them, lol.
- You may not post replies
- You may not edit your posts
Forum Rules
