kawasaki 550sx 1994
Results 1 to 10 of 16
    Sep 2016
    ohio
    3
    kawasaki 550sx 1994
    94 sx , I cant seem to locate a ebox for this unit, I need a coil and cdi , they are different than the js ebox ive been down that road any body know of or have an ebox to sell
    Sep 2016
    Swansea
    Re: kawasaki 550sx 1994
    HI I'm new to this looking for some help.
    I have a Kawasaki 750zxi that starts on the button but when I put it in the water it only does about 10mph!!!
    It tries to accelerate but just revs and doesent go anywhere . And the engine seems to over heat any advice would be appreciated ??!!!
    Sep 2016
    ohio
    3
    you probably have debris in your pump causing cavitation which also doesn't force the water up to the engine , just clean out the debris. could be a stick , grass, plastic bag .
    Sep 2016
    Swansea
    Thanks will take a look
    Jun 2014
    Seattle
    Pm this guy: Bionic racing
    I'm sure he's got something
    78 JS440
    -Ocean Pro Finned Ride Plate
    -Westcoast Intake Grate
    -SCR Ported Cylinder
    -Mariner Waterbox
    -Primer
    -SBN44
    -Quick Steer
    -Skat~Trak 16.5 SS Impeller
    Aug 2011
    Austin, Texas, USA
    Quote Originally Posted by Dan Ritter View Post
    You would obtain much better results in posting this in the want to buy section (linked below). Lots of part sellers watch that section judiciously.
    http://www.pwctoday.com/forumdisplay.php?f=22
    Quote Originally Posted by Leeweimaraner View Post
    Post this question in the Kawasaki technical discussion section: http://www.pwctoday.com/forumdisplay.php?f=16
    Riding mostly Lake Austin
    Sep 2005
    AZ
    Not sure what road you took but the parts are interchangeable. What do you mean by CDI? There is a start/stop switch that look different but function the same. On the 1994, it will also have a green wire going to the spark coil that is the rev limiter connection.
    1989 Wet Jet - Upgraded 1994 50 HP motor & exhaust.
    Mar 2017
    missouri
    I'm trying to purchase an ebox for a 1991 JS 550 c1
    Please let me know if anyone may be able to assist me,
    PWCToday Newbie Tim Patmont's Avatar
    Lathrop (River Islands), CA
    Quote Originally Posted by MrSki View Post
    Sorry to dig up an old thread. Mr. Ski, or anybody, do you know which wire you disconnect to bypass the rev limiter on the 91 550sx? I'm pretty sure the wire was a different color for this year. Used to know this, but it's been a LONG time...
    1993 Novice 550 Limited National Champion - Lake Havasu World Finals
    1993 Novice 550 Limited California State Champion
    2000 Pro Go-Ped Overall World Champion
    The Original, Go-PedŽ Brand Scooters
    Shout out to NorCalStandupCrew!
    Sep 2016
    ohio
    3
    Quote Originally Posted by Tim Patmont View Post
    mine is is 94 I disconnected it last winter because the engine would not rev up, the limiter was premature, all I remember is the wire that comes from the limiter to the coil is the one you disconnect but then it wont shut off so you will have to ground coils positive side using the existing wires to the rev limiter which also shuts down the motor
