Results 1 to 10 of 15
    PWCToday Guru bkh91171's Avatar
    Jun 2013
    Dana Point, CA/ Gilbert, AZ
    Clearing out some stuff
    Hey There Everyone,
    Have a few things I'm trying to clear out of the garage.
    Off 93' 750 XI
    Ebox (works perfect, but wires shorter than stock)- $75
    Stator- $75
    Flywheel- $25
    Off 94' WR III 650;
    Crank (has some rust)- $30
    Cases- $20
    Cylinder (needs a bore)- $20
    Pump/Driveshaft/Solas Prop- $100
    Midshaft- $35
    550 Misc;
    FPP Half Pipe (have adapter, but bolt broken off)- $75
    TRE Head (no idea on compression)- $50
    440 Hull w/CA Title and Current Reg- $500
    Hull includes, PJS 440 Pump, PJS Prop, PJS Quick Steer, PJS Nose Block off
    Jun 2013
    Re: Clearing out some stuff
    All Prices are OBO!
    Jun 2013
    Make an offer/s!
    Mar 2007
    Is Everything!
    Is the TRE head PP or reed ?
    Jun 2013
    PP. I apologize though, I've never ran it, so I couldn't give you an idea of compression.
    Jun 2013
    Bump!
    Jun 2013
    Bump it!
    sacramento
    Which pump?
    Jun 2013
    Looks like an Afterburner, but not 100% sure? Will need cleaning and probably bearings.image.jpg
    Is there any way that's Jeff Manges, that used to work at Jetco?
    sacramento
    Why yes it is who is this?
