Results 1 to 10 of 12
    PWCToday Regular Csmith721's Avatar
    Aug 2013
    winchester TN
    97 Kawasaki 750sxi part out
    97 Kawasaki 750sxi full part out, every thing is in good workin condition. I'm holding onto the motor and electronics every thing else goes..
    Hot products straight bars $65
    Westcoast intake grate $125
    Worx ride plate $125
    Hood $200
    Hood latch $45
    Gas door with lock $75
    Water box $75
    Water box hoses $20
    Gas tank $75
    Oil tank $40
    Gas tank tubes $20
    Pump $350
    Rubber oil tank pads $10
    Prices do not include shipping all parts are in clean working condition,
    Jun 2016
    Iowa
    Re: 97 Kawasaki 750sxi part out
    Hull for sale then???
    SE MI
    Pictures of inside the hull?
    PWCToday.com Is My Home Away From Home afraz1er's Avatar
    Oct 2007
    BOISE
    Quote Originally Posted by Csmith721 View Post
    Hood $200
    Hood latch $45
    Water box $75
    Water box hoses $20
    Gas tank $75
    Oil tank $40
    Gas tank tubes $20
    Pump $350
    Looking for the exhaust to cylinder brace, the pad on the under side of the pole, and exhaust to water box hose.
    Sent from my XT1650 using Tapatalk
    - 03 Superjet - 1mm over bore, hooker 9/15, destroyer tubbies, carbon ride plate, cold fusion turn plate, quick steer mod, UMI bars, blowsion pole spring, jetmaniac girdled head, limited chamber b pipe
    - 94 WB1 - protec ride plate and top loader, 61x61x (FOR SALE)
    - 92 550sx - under construction
    - SNSJ - dual 44sbn, protec girdled head, 735cc, 62t61x, cylinder ported by tim tynan, protec exhaust, bored nozzle, 10/16, worx 201 top loader
    Jun 2016
    Michigan
    Do you have the pole pin assembly?
    Aug 2013
    winchester TN
    Hull is for sake if your still interested
    SE MI
    Did you ever get pics of the engine bay?
    Feb 2002
    Vancouver, BC Canada
    That's a 96. 97 was not sold or available in the USA.
    http://www.pwctoday.com/showthread.p...=1#post3007962
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
    Aug 2017
    Tonawanda NY
    Looking for oem siphon pump setup, battery straps and clips. Do you have available and price?
    Jun 2016
    CT
    Still have the waterbox?
